1nz-fe motor removal/installation pics and/or instructions
Old Jun 26, 2008 | 10:18 AM
xa007xa's Avatar
Default 1nz-fe motor removal/installation pics and/or instructions
can anyone point me towards instructions on pulling the motor? i'm hoping to swap motors july 4th weekend and hoping to find something more than what my pdf file of the service manual offers.
Old Jun 26, 2008 | 05:07 PM
biohazardous_customz's Avatar
well i did the same exact thing and the entire swap took me 2 days and thats only because i was fabbin stuff for the turbo at the same time......if you have questions let me know id be more than happy to guide u
Old Jun 29, 2008 | 10:52 AM
xa007xa's Avatar
did you pull the motor up and out or through the bottom? did you pull the motor with the tranny still attached?
Old Jun 29, 2008 | 10:56 AM
itsme's Avatar
i pulled mines through the bottom........
Old Jun 29, 2008 | 09:57 PM
xa007xa's Avatar
what about special tools? ball joint separator, etc...
Old Jul 1, 2008 | 02:33 AM
blown_xa's Avatar
here are a few tips: I have pulled my motor many times (unfortunatly) and have done so a few ways.
I have pulled my motor out and had the replacement on the engine jack ready to go in in less than 5 hours..
Trans comes out with motor
it makes it MUCH easier if u remove radiator/ac condensor, but if not at least remove fan assembly or it will get crushed.
disconnect fuel line from fire-wall, no special tool needed, just remove outer plastic coupler, then push button with finger to release quick connect fitting.
use vise-grips to remove shift linkage slide locks, and spray with oil before hand.
only other really tricky thing that sticks out in my mind is the power steering pump... i leave the fluid lines connected but remove the pump from the block as a last step before motor is removed ( last step because one of the bolts holding the pump is too long to remved when motor is in place and hits frame rail.)
if u have any questions, PM me.
Old Jul 1, 2008 | 02:36 AM
blown_xa's Avatar
oh as far as special tools, none needed... but u do need a 30mm (31mm works) 12 point socket with a strong impact to remove axle nuts. removing axles make it easy.
oh yea i forgot.... make sure u remove throttle cable from throttle body, and slave cylinder from trans, and the slave cylinder hard line bolts to top of trans also, make sure it is free.
Old Jul 1, 2008 | 02:40 AM
xa007xa's Avatar
cool. thanks. i ordered up the service manual in hard cover cause the pdf i have doesn't cover removal and replacement. built motor is ready to go. have most turbo parts installed that would seem a pain to do in the engine bay. figured on removing the radiator cause i just put in a koyo and i don't want to mash it up.
my plan of attack is to remove the hood. then intake and exhaust manifolds. accessories. and motor and tranny up and out. will the motor and tranny come out from the top attached?
will take pics to post
Old Jul 1, 2008 | 07:19 AM
itsme's Avatar
i've taken out the motor multiple times as well (unfortunatly)and found it to be alot easier to remove and install the motor from the bottom of the car........
Old Jul 5, 2008 | 08:50 PM
xa007xa's Avatar
i ended up dropping the motor down on the ground and disconnecting the tranny then hoisting it up and out. did this cause I didn't have enough lift with the jack stands. just waiting on bearings for my differential and then it should be getting in. hopefully all will be done by next weekend.
YooItsJay
Dec 2, 2015 08:13 AM
Andreas24
38
Sep 22, 2015 06:23 PM
NonStopTuning
Jun 29, 2015 07:42 PM
kleecker
Feb 12, 2015 11:02 PM
eric_m
79
Mar 17, 2013 12:21 AM
