Resetting long term fuel trim in ECU?
Old Jan 9, 2009 | 05:13 PM
enjoithis's Avatar
Default Resetting long term fuel trim in ECU?
My long term fuel trim is -36 and dropping! I have figured out that it was dropping because i was running richer than the o2 map in the F/IC called for, so the ECU adjusted for it. (Well thats my understanding)
Does anyone know if unplugging the ecu for an hour or so would reset that value?
I did try reverse engineering the fuel trim. Set my fuel map at idle to -30, and the o2 to about 1.3v i think (12afr) in hope that the ECU would adjust the long term fuel trim to compensate for the extremely lean idle. However - clearly didnt work. I think it only adjused the short term fuel trims since it was only at idle, i didnt really want to mess around with other ranges in the map. Any other suggestions?
Old Jan 9, 2009 | 10:04 PM
enjoithis's Avatar
anyone?
Old Jan 12, 2009 | 01:08 AM
enjoithis's Avatar
i always post unanswered questions!
Old Jan 12, 2009 | 01:13 AM
Superpickel's Avatar
no, your post just fall into the twilight zone. Do do do do do do do do...
Old Jan 12, 2009 | 01:22 AM
etoomey3's Avatar
You could try unplugging the ECU or the Battery for an hour or so, and the computer might reset itself and it's adaptives, I know disconnecting the battery for a while will reset the Check Engine Light
gp1817
Mar 18, 2015 10:26 AM
yhwhdesign
Mar 7, 2015 02:01 AM
eric_m
79
Mar 17, 2013 12:21 AM
salsa0shark
32
Jul 12, 2005 04:43 PM
XTRMGMR
Dec 11, 2003 05:35 PM
