toyota flange nut
Old Dec 24, 2011 | 02:37 AM
op4dc4's Avatar
Default toyota flange nut
Hi everybody does someone try to fit acorn standars nut on the oem wheel because I want colored nut but I dont want to buy aftermarket wheel .Thanks a lot in my mind I dont think so because oem wheel at the bottom on the nut its flat and a normal car its conical .thanks.
Old Dec 25, 2011 | 07:38 PM
Blackedout011TC's Avatar
Not a good idea, they must have a flat washer like the stock ones.
Old Jan 25, 2012 | 09:19 PM
bionictony's Avatar
not safe. don't do it.
Old Jan 25, 2012 | 09:29 PM
Backinblacktc2's Avatar
How about painting or powder coating the oem lugs. Just make sure they cover the threads.
Old Jan 26, 2012 | 02:51 PM
Buy an extended al. lug, hard annodized of course in the color you want. Cut and grind the conical surface down flat. Then find a washer that matches the ones attached to the stockers.
Also the lugs can be chucked into a lathe at a machine shop and cut down perfectly. Take a stock lug with you to the shop so they know what to shoot for.
Just an idea.
Old Jan 30, 2012 | 12:08 AM
PandaTC2's Avatar
I have bwr open ended extended lug nuts in black. I haven't had any problems. Y'all scare me now O_o what's the problems?
Old Jan 30, 2012 | 12:09 AM
PandaTC2's Avatar
On my stock rims btw!!!
Old Jan 30, 2012 | 02:39 AM
dstock1088's Avatar
You can't put acorn nuts on alloy wheels. The wheels are centered on the hub not the lugs.
My verdict: It's not safe. DON'T DO IT.
Old Jan 30, 2012 | 02:38 PM
WellesleyScion's Avatar
As a kid, did you ever try fitting the square block into the round hole? Same idea here...
Old Jan 31, 2012 | 03:13 PM
ProjectTC2's Avatar
Ouch! Yea man major safety hazard. Those big washers on the stock lugs are made to clamp down the stock rims, aftermarket lugs aren't gonna have the same size or shape
Old Jan 31, 2012 | 04:55 PM
Old Feb 1, 2012 | 02:26 PM
PandaTC2's Avatar
When when I get my aftermarket wheels I can use them?
Old Feb 1, 2012 | 02:31 PM
PandaTC2's Avatar
Originally Posted by WellesleyScion
Isn't it a bit odd how all of them come off at the same time?? IMO
Old Feb 1, 2012 | 03:47 PM
PandaTC2's Avatar
Ok either way I just took them off and put the stock ones back on. Thanks guys I saw the difference and wtf was I thinking. Lol the bwr ones had a cut around them from where they were mounted on the rims and not to mention not even torqued to where I torqued them so they were getting loose I'm happy I got this info early so I guess I can hold them till I get my rims.. I'm getting the xxr 526 18x10.5 +20 offset. Will I be able to use these bwr on the xxr???? Thanks guys and to answer Tue original question on this thread DONT DO IT!!!!!!!!!!
Old Feb 1, 2012 | 05:33 PM
The XXR's are acorn style, so you should be fine with the bwr's on there.
not really, it just means they all loosened up at the same rate...
Old Feb 1, 2012 | 08:10 PM
PandaTC2's Avatar
hell yeah i cant wait to get my rims......
thanks for the help realy appriciate it..
Old Feb 4, 2012 | 09:07 AM
18x10.5 +20= another bad decision right there with your lug nut fail. That size wheel is too aggressive to be functional unless you plan on a wide body kit. Bigger is not always better. If your going for looks, that initial smile will quickly fade when you realize you can't drive the car safely or even remotely aggressive. Don't give up an ounce of performance for "static" apeal. Dropping 9lbs. of weight on my rim choice made mine so much more fun to drive. I get compliments on my car's looks almost daily from all types of people. The whole hella flush, poke, tuck, taint tickle and aggressive thing is just over-rated forum and car show hype imo. Just my 2 cents. Good luck with whatever you choose, it's your ride. I just wanted you to rethink your choice.
Old Feb 9, 2012 | 03:19 PM
john2011TC's Avatar
Oh mann I didnnt even know these flange nuts made a difference. Thanks for the info
scionlife
371
Jun 2, 2015 11:00 PM
BManAmericae
Jan 18, 2015 12:17 PM
Ramroids55
Jan 16, 2015 02:42 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
2002cbr600f4i
12
Oct 11, 2004 11:38 PM
