toyota flange nut
Hi everybody does someone try to fit acorn standars nut on the oem wheel because I want colored nut but I dont want to buy aftermarket wheel .Thanks a lot in my mind I dont think so because oem wheel at the bottom on the nut its flat and a normal car its conical .thanks.
Buy an extended al. lug, hard annodized of course in the color you want. Cut and grind the conical surface down flat. Then find a washer that matches the ones attached to the stockers.
Also the lugs can be chucked into a lathe at a machine shop and cut down perfectly. Take a stock lug with you to the shop so they know what to shoot for.
Just an idea.
Just an idea.
Ouch! Yea man major safety hazard. Those big washers on the stock lugs are made to clamp down the stock rims, aftermarket lugs aren't gonna have the same size or shape
Ok either way I just took them off and put the stock ones back on. Thanks guys I saw the difference and wtf was I thinking. Lol the bwr ones had a cut around them from where they were mounted on the rims and not to mention not even torqued to where I torqued them so they were getting loose I'm happy I got this info early so I guess I can hold them till I get my rims.. I'm getting the xxr 526 18x10.5 +20 offset. Will I be able to use these bwr on the xxr???? Thanks guys and to answer Tue original question on this thread DONT DO IT!!!!!!!!!!
18x10.5 +20= another bad decision right there with your lug nut fail. That size wheel is too aggressive to be functional unless you plan on a wide body kit. Bigger is not always better. If your going for looks, that initial smile will quickly fade when you realize you can't drive the car safely or even remotely aggressive. Don't give up an ounce of performance for "static" apeal. Dropping 9lbs. of weight on my rim choice made mine so much more fun to drive. I get compliments on my car's looks almost daily from all types of people. The whole hella flush, poke, tuck, taint tickle and aggressive thing is just over-rated forum and car show hype imo. Just my 2 cents. Good luck with whatever you choose, it's your ride. I just wanted you to rethink your choice.
scionlife
371
Jun 2, 2015 11:00 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
2002cbr600f4i
12
Oct 11, 2004 11:38 PM
