is there any way to lower rpms
Old Nov 26, 2005 | 02:14 AM
BUDDA's Avatar
Default is there any way to lower rpms
seem to be a little high dont they?
Old Nov 26, 2005 | 02:42 AM
ScionSpouse's Avatar
not really. no gears in the rear end
Snarky sarcasm aside, I don't know whether the differential in the xB can be altered
Old Nov 26, 2005 | 02:43 AM
xBHAWK's Avatar
Default ....WRONG, WRONG, WRONG.....
Are you in the right chat room? XB's are front wheel drive.
They have no rear end. (Where is my a$$ at?)
You could change the rear end gears but you would have to add a rear end first.
I got my RPM's down by moving the needle in the tach, now I never go over 3000 rpm.
ORIGINAL SUBJECT LINE READ:
CHANGE GEARS IN THE REAR END TO BRING DOWN RPM's.
Old Nov 26, 2005 | 01:32 PM
Metro273's Avatar
Default Re: ....WRONG, WRONG, WRONG.....
Old Nov 26, 2005 | 01:43 PM
hotbox05's Avatar
well swap transmissions with a toyota echo... or get an auto.
Old Nov 26, 2005 | 01:57 PM
xA_Factor's Avatar
Or put some 35 inch wheels/tires on it.
J/K.....There's really no practical way, other than what hotbox05 said....neither which would be very cheap.
Old Nov 26, 2005 | 03:24 PM
Romanova's Avatar
I'm sure you could get an Echo tranny for next to nothing from a junk yard. If you are mechanically inclined, you could swap trannys in a day... nothing too complex in removing the transmission.
Old Nov 26, 2005 | 07:43 PM
Rocket's Avatar
Adding a taller tire would raise the gear ratio by a small degree.
Old Nov 26, 2005 | 07:44 PM
BeQuietAndDrive's Avatar
And then you could rejoyce at your extra-sluggish acceleration...
Old Nov 27, 2005 | 02:28 PM
Rocket's Avatar
As this member points out any raise in gear ratio will lower the power at take off.
Old Nov 27, 2005 | 02:40 PM
dgHotLava's Avatar
echo trannies do not fit....diff mounting tabs.
you can get TRD final drive gears...
you can swap out the gears from an echo, not the whole tranny.
Old Nov 27, 2005 | 02:48 PM
hodad66's Avatar
Scion Dynasty
Taller tires is the cheap way..... slower off the line but less rev's overall
Old Nov 28, 2005 | 01:45 AM
Sciond's Avatar
gear swap seems like the way.....
Old Nov 28, 2005 | 02:06 AM
jct's Avatar
jct
i got used to my high rpm's thats where my header likes it at
Old Nov 28, 2005 | 03:09 AM
dgHotLava's Avatar
also gives you a reason to do all the other cool things in that dept...
light weight flywheel...
clutch...
LSD...
front sway (easier with the front end down...)
front braces...
Fisqual
Sep 22, 2015 05:51 AM
hampton1100
May 28, 2015 07:32 AM
Bobb_Todd
Jan 16, 2015 06:57 PM
cid_mcdp
Jan 5, 2015 02:45 PM
stankubrick
21
Jan 4, 2004 06:30 PM
