Amp hookup trouble... where is the hole in the firewall?
Old May 23, 2006 | 05:38 AM
Snoodge's Avatar
Default Amp hookup trouble... where is the hole in the firewall?
Im pacing around the car trying to find where I run the power cable for my amp from the engine bay into the drivers side interior and I dont see where the wires go through. It was easy as hell to do on the xB.
Does anybody have a guide link for this or a closeup picture of where the wiring goes through?
Old May 23, 2006 | 01:44 PM
BrEaK_AwaY's Avatar
the grommet under the drivers dash. you will have to cut a little slit into it to get the wire through. it is very high on the firewall. it is above the TB in the engine bay
Old May 23, 2006 | 01:49 PM
Borisimo's Avatar
You don't have to cut anything if you slip the wire between the edge of the grommet and the hole in the firewall. I got a bunch of wires going through there.
Old May 23, 2006 | 01:52 PM
DanPorges's Avatar
As a certified installer let me offer you fair warning. Be VERY careful when you do that. The metal edge that that grommet is now pushing your wire against could very easily cut the plastic or rubber coating on the outside of the wire, especially if have Bass Vibration assisting. If thats a power wire, it will at minimum blow some fuses, but could be alot worse if the line is not fused.
Old May 23, 2006 | 01:55 PM
BrEaK_AwaY's Avatar
i was about to say the same thing. please do not correct me with wrong information. if you splice that wire with it rubbing the firewall... and the fuse dont stop it... KABOOM!
make a small slice in ur grommet, and run the wire though SAFE.
borismo, i suggest you put an inline fuse on every wire you have that go through ur firewall in the manner.
Old May 23, 2006 | 02:32 PM
mandos's Avatar
Link to guide in sig.
Please cut it
Driver side:
https://www.scionlife.com/forums/vie...highlight=runs
Passenger side:
Old May 23, 2006 | 02:38 PM
Stu_Gotti's Avatar
Mandos is God.. Vote Mandos! Brah.. you should start your own magazine or something.. just call it "Mandos Mobile Car Audio".. or a business.. it has its ring
Someone make this man a Mod.. Stat!
Old May 23, 2006 | 02:42 PM
mandos's Avatar
I'm a mini mod for ICE
Old May 23, 2006 | 03:24 PM
Borisimo's Avatar
I forgot to mention that I do use a mini-grommet around the wire itself to protect it from the firewall and ofcourse always use an inline fuse on my power wires. This way if I ever remove the wiring, I don't have a hole in the stock grommet.
Old May 23, 2006 | 03:41 PM
mandos's Avatar
Ahhh...that definitely makes it mucho better
Grommets = good.
Old May 23, 2006 | 04:59 PM
BrEaK_AwaY's Avatar
good. just lookin out for the safety of scion owners =]
Old May 23, 2006 | 05:06 PM
Stu_Gotti's Avatar
Old May 23, 2006 | 05:13 PM
TwztedtC's Avatar
drill a hole in the firewall and use grommets just watch where you are drilling
Old May 23, 2006 | 06:50 PM
engifineer's Avatar
what would mandos know about taking apart the tc???
heh heh
Old May 23, 2006 | 09:46 PM
SquallLHeart's Avatar
Old May 24, 2006 | 08:41 PM
aacordon's Avatar
i used some platic crommet coveers from the water cooling kint in my computer for the firewall hole behind the driverside strut and wired my amp and fogs through there.
yupinmytC
22
Jul 27, 2024 07:08 PM
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
user9430961
Sep 24, 2015 01:09 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
DannyBoy65
Sep 21, 2015 06:23 PM
