HID Problems please help
Old Oct 26, 2007 | 03:18 AM
samos's Avatar
Default HID Problems please help
Ok so ive searched and visited all the hid headlight problem topics and cant seem to find a straight away answer to my problems. Both of my head lights are out. at one time one went out briefly while i was driving but then came back on and had been fine until the other morning when i turned my car on and no lights. Ive re connected basically every wire and checked the fuses in the fuse box, none blown
Any suggestions? or answers?
Old Oct 26, 2007 | 03:20 AM
Yanki01's Avatar
probally one of those "you get what you paid for" deals right about now i would think? Bad wires, ballast, bulbs....? Got warranty on it?
Old Oct 26, 2007 | 03:25 AM
amdforever's Avatar
Does the ballast plug directly into the stock car harness? If so, look at as much as possible of the stock harness and see if it burned itself up.
Old Oct 26, 2007 | 04:26 AM
BZinn1's Avatar
^^^^Look for damage.........test with meter to se if you have power to ballasts......if you do.........then ballasts can be toast......check with meter fro power after ballasts........if you do then bulbs are toast...........but my guess is ballasts first.....or harness........and never buy anything cheap fro your car ..........what kit...........perhaps we can figure out what is fried.......but sounds like balast.....
Old Oct 26, 2007 | 04:36 AM
amdforever's Avatar
did you check both fuse boxes? I dont have my tC to go look for you but just wondering if you checked both. the odd thing is only one went out and then after a period both just went out.
Old Oct 26, 2007 | 04:37 AM
Viace's Avatar
upgrade your fuses
Old Oct 27, 2007 | 04:16 AM
samos's Avatar
working on checking these things i guess ill get back to you tomoro thanks alot
Old Oct 27, 2007 | 02:21 PM
samos's Avatar
it appears i have power going into the balast and basically none coming out.. so a blown balast?
Old Oct 27, 2007 | 04:43 PM
striker_1818's Avatar
hook them up directly to the battery.
If that doesn't work, then you know for a fact your ballast is blown.
but BE CAREFUL!
Old Oct 28, 2007 | 04:06 AM
cliffud's Avatar
samos-
Please check out the installation instructions on my site and make sure you ground to the battery and check out the troubleshooting steps.
Thanks.
http://www.mobilehid.com/support.htm
Clifford
Old Oct 28, 2007 | 11:58 PM
taco's Avatar
Originally Posted by blackonblack91
upgrade your fuses
never upgrade fuses, fuse are there so u dont get a fire.
make a harness would of been a better awnser.
or kit suck and blind everyone. retro ftw!
Wolfgang94
Mar 24, 2015 12:48 PM
S7ephavs
Mar 22, 2015 12:09 PM
GoodVibes
Mar 10, 2015 04:29 AM
mvez
Scion tC 2G Aero & Exterior
Feb 4, 2015 01:15 AM
tc_Jake
Dec 31, 2014 01:45 AM
