Need help on a flexplate problem.
Old Mar 15, 2009 | 05:31 AM
tiksman's Avatar
Default Need help on a flexplate problem.
I have a xb company car. It had a blown engine. The #4 rod had knocked a hole in the oil pan and both sides of the block.
Anyway,
Put in a used engine and the starter wont engage correctly.
There is a dent in the starter where a piece of the block hit it.
There also was metal shavings in the bellhousing and starter.
I cleaned out the starter and the bellhousing (took the starter apart)
I thought everything was good but.... I NEED HELP.
Could someone with a automatic and mechanical know-how remove the plastic inspection cover that covers the flexplate and tell me or take a photo of the flexplate teeth. I need to know if you can see the welds on the flexplate to the teeth or if there is a 1/4 inch lip on the teeth to the flexplate. If so I put the darn flexplate on backwards . If not I have a bad starter.
I know this is a first post but I need help on this asap Please!
Old Mar 21, 2009 | 02:02 AM
tiksman's Avatar
WOW!!!
I got more help over at Yarisworld than I got here.
Incase everyone was wondering the flexplate was on backwards.
I swapped it over today.
There is a ring pressed in to the flexplate the rise points to the engine and the valley goes to the converter.
Thanks for the help and replys
Old Mar 21, 2009 | 12:00 PM
jct's Avatar
jct
np thats what we're here for
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
Forced4
Aug 25, 2015 08:18 PM
TheRealShark
Scion tC 2G ICE & Interior
Aug 5, 2015 05:08 PM
capgrover
Jul 25, 2015 05:00 PM
blackpearlTC
Jul 19, 2015 04:55 PM
