Quick Enclosure Question....
Old Mar 4, 2004 | 12:03 AM
Docsnuff's Avatar
DelMarVa
Scion Tuners
Default Quick Enclosure Question....
With the design of the xB the way it is, what is the best type of enclosure?
1. Closed
2. Ported
3. Bandpass
I am gonna buy my box soon, and I am just wondering what you experienced sound techies think?
Thanks,
Doc
Old Mar 4, 2004 | 12:08 AM
superjeer's Avatar
It's been years since I've done sound, but at least in my day, I'd go with sealed. It's a tighter less noisy sound, and the xB being trunkless will transmit any noise up since there's nothing to baffle it out.
Old Mar 4, 2004 | 12:13 AM
obz's Avatar
obz
From what I understand (I could be mistaken but have been told this by a few audio people) bandpass gives you the best bang for you buck. It gives a bit deeper base as opposed to ported or sealed.
Old Mar 4, 2004 | 12:19 AM
rattmobbins's Avatar
Bandpass or ported are gonna give you more bass, but it'll be sloppy. Sealed gives you nice tight bass but it doesn't hit quite as hard. It all depends on what you listen to most. If you listen to a lot of rock, then definately go sealed. Rap or Tecno, the choice is really up to you. I have always rocked sealed boxes because I prefer quality over quantity and sealed boxes just sound cleaner!
Old Mar 4, 2004 | 12:21 AM
rjsalvi's Avatar
Default Re: Quick Enclosure Question....
1. Closed
2. Ported
3. Bandpass
Thanks,
Doc
Are aesthetics an issue? Unless you plan on damping the interior, I think a bandpass or ported enclosure will be too "boomy" for an xB. You might consider an isobaric.
Old Mar 4, 2004 | 12:25 AM
MrSmiley's Avatar
sealed box ... tighter, cleaner sound ... no muddy bass..
Old Mar 4, 2004 | 12:45 AM
showpaojoe's Avatar
IV ACE
ported if you want more boom like they say. i think i'm gunna port mine cuz while the bass is extremely clear, it doesn't it as hard as i'd like
Old Mar 4, 2004 | 12:49 AM
Docsnuff's Avatar
DelMarVa
Scion Tuners
I plan in using sone Dynomat as needed, but I really just want tight bass. If I need a sealed box to do that then thats good. I thought a bandpass box had crisper and tighter bass?
Doc
Old Mar 4, 2004 | 12:55 AM
Munch's Avatar
Sealed boxes have the tightest bass.
Old Mar 4, 2004 | 12:57 AM
sho nuff!
Old Mar 4, 2004 | 01:17 AM
usdmbB's Avatar
Alrighty first all three boxes will work. Your needs are the most important
as far as a box goes. First how much space do u wish to give up, Second how loud
do you want to be and Third what kind of speakers(brand and sizes). Now that we have that down lets look at what differant boxes will do. Sealed boxes will play
loud and handle more power, and some say more musical. Next a ported box will
give you more out put with less power in most cases, most hardcore spl people use
ported boxes. Some ported boxes will some times have port noise kinda like a whistle noise from the port. In my own xb i fun a single 10" in a ported box.
Now on to bandpass boxes first i will say a properly built bandpass will perform
as well in sq as any other box only problem would be size. MOST PRE BUILT BANDPASS SUCK other than some of the ones built buy the speaker manuf.
JL audio had some good bandpass boxes as did aluma pro.
The best advice i can give you is go and listen with your own ears PERIOD
if you dont like it dont buy it!!!! And dont let some sales guy get you . Only get what you like.
Oh yea issobaric this used to be a great way to get more woofers in a car , but with how small a box most need this is not a good choice
You can pm me with any questions iam happy to help
Old Mar 4, 2004 | 01:54 AM
KingLou's Avatar
It may depend on the sub. Some subs are designed specifically for small sealed enclosures.........and some for big fat ported enclosures. But.....in general..........a ported box will give you louder, more "boomy" bass. With a sealed enclosure.......you'll get tighter, snappier bass, with a bit of a decrease in SPL. However, another benefit of sealed is that you can usually get away with smaller enclosures, and the sealed design helps reduce excursion on the sub, and prolong the life of the speaker. Sealed boxes are also cheaper and easier to build. I'd say.........for regular listening......go sealed. If you're joining SPL competitions.......or are just one of those guys that can't get enough bass (Mark....i'm looking in your direction ) then go with a ported or bandpass enclosure.
KiL
Old Mar 4, 2004 | 02:13 AM
Docsnuff's Avatar
DelMarVa
Scion Tuners
I currently have and plan to keep:
2 Alpine Type R 12's
each powered by their own Bazooka EL1500.
If you know these components, give me an idea on what box to use for my xB!
Doc
Old Mar 4, 2004 | 02:50 AM
rjsalvi's Avatar
Doc
Here's a good primer on enclosures, Doc:
http://www.audiovideo101.com/diction...ctionaryid=180
Unfortunately, speaker building with the intent of linear response is a bit more involved than speaker building for max. SPL (sound pressure level) at 20Hz. For instance, choosing a proper driver(s) requires knowledge and interpretation of what are known as Thiele-Small Parameters (electromechanical properties of a speaker driver:
http://www.eminence.com/eminence/pag...s02/params.htm
http://www.silcom.com/~aludwig/Sysde...l_analysis.htm
I don't mean to dissuade you from undertaking a sub project , just that there's more to it than slapping a driver in a box.
Old Mar 4, 2004 | 03:01 AM
Docsnuff's Avatar
DelMarVa
Scion Tuners
I appreciate the input RJ, and actually I have the drivers, I wanna slap a box around them!!! So I guess I need to do some reading. Do you have a quick answer for me though?
Doc
Old Mar 4, 2004 | 03:11 AM
DenZinz's Avatar
well said
Old Mar 4, 2004 | 03:40 AM
OrangeScionC21's Avatar
I have a Backwave box from The Woodshop, a local competition company. That is a stock picture of it below. I am running two of their Texas Baase Subs (also below) with an MTX 8100D Amp, let's just say, it hits Hard!!
The website is: www.The-Woodshop.com
Now as far as quality w/ the music, It sounds pretty good. It isn't the cleanest thing on earth, but it is tight to a point. It does peak at some points, which is the major problem with ported enclosures, but other than that, it is awesome.
Definitely worth looking into.
rjsalvi's Avatar
Doc
No quick answer, but here's a link to a box calculator:
http://www.mhsoft.nl/spk_calc.asp
and here's a link to the specs. of your driver:
http://iweb.alpine-usa.com/pls/admn/...in=10&p_more=y
Have fun.
Old Mar 4, 2004 | 04:08 AM
scionracerxb's Avatar
BAZOOKA....(not the dealer one tho)
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
BlingSlade
Sep 5, 2015 08:52 AM
javio24
Aug 23, 2015 01:07 AM
mc1114
Aug 12, 2015 02:07 AM
SoCal_CJ
Scion tC 1G ICE & Interior
Jul 14, 2015 09:14 PM
