changing gear oil on 5spd question...
Ok, so let me get this straight.
Some people are using regular mobil synthetic oil, 5w 30
some people are using redline mt-90
and some people are saying that those are bad.
I am sorry, but i am so clueless right now, and i been reading alot but some seem a little bias, and i am sitting at 15k without knowing about this, and i am sort of worried.
So can more people comment on this subject, also can someone make a write up or directions on how to do this change?
Like i read you have to pull one plug before the other?
thanks for your time.
Originally Posted by Tamago
Originally Posted by Dr. Isotope
According to the service manual, the MTF isn't even set for inspection until the 30k mark. It's only recommended for replacement at 60k if the vehicle is used in "special conditions".
Why shouldn't you put regular Mobil One in a transmission? Synthetic oils are too slick. Transmissions generally appreciate a fluid with a friction enhancer, seeing as how they rely on the meshing of gears to operate. There is absolutely no reason under the sun not to be using Toyota MTF in the trans... of course, there's no need to be replacing it at 10k miles, either.
But hey... get on with your bad self.
but hey, stick with your "toyota recommended" if you want.. i'll stick with common sense.
-Paul
-Paul
money? $5
and your warranty is NOT affected by changing fluids...
open your owners manual. use oil recommended for your transmission LISTED IN OWNERS MANUAL..
i have a question... when you do the change.. when adding more fluid do you have to turn the engine on.. i know for an auto you have to.. but a manual i don't know... and also after reading .. i'm guessing redline mt90 is the way to go...
-Paul
The factory gear oil is like Wesson (cooking oil) and the stuff I replaced (MT-90) is like Gold Honey. From a technicians standpoint you should know they put in crap (NooB).
My gearing was very notchy and shifted harsh, but now it's like finding my favorite parking spot at the beach.....
MT-90 is the best, because it's designed to protect syncros even during cold and hot temp..... It has been tested and proven, for my own experience and many others.
The xB, IIRC, calls for gear oil, not transmission fluid.
I'll stick with the specified weights that the manual recommends, but I'm definately going synthetic. I've used Redline MTL in my previous car and it made a huge difference in shifter feel. I'll probably use Redline 75w-90 NS. I believe that's within Scion's recommended weight ranges for the xB's 5-spd.
So i am going to buy some Redline MT 90 this weekend and plan on doing the change but i was wondering for the tc how to do this change?
I looked but dont really understand what i am looking for?
And is there any no no's i should look for like doing an oil change its wise to plug the plug back in before pouring the oil in ^_^
cause i thought i read something abou taking one plug out before the other.
thanks for all your help it really cleared up my cloud of misconception.
thanks
thanks
Ok, first off :
Know damn well that you're draining the transmission and not something else. Since I don't have a tC, I can't help you w/ what to look for.
Tips:
Look in your manual and find out just how much fluid your transmission requires.
Warm fluid flows a little better than cold fluid. Don't burn yourself, though!
Fill and drain plugs - there's usually 2 plugs on your tranny. 1 to fill the tranny (usually on top of the tranny) and one to drain (usually down low on the tranny). Make sure you can get the fill plug open before you drain all the fluid out.
Tips:
Let me get this straight... so Redline MT-90 is gear oil, i've seen it called transmission oil/ lubricant. I'm a newb, help.
I just changed mine today at a little over 40K. The fluid was a lot darker than I expected and had a lot of gold metallic shimmer to it. I'm hoping that's normal wear. I replaced the fluids with Mobil 1 gear oil.
From what I saw I wouldn't recommend waiting until 60K to change the tranny oil. They also recommend 5000 miles for engine oil but most people do it at 3000. No sense in taking any chances. Trannys and engines are expensive to replace.
Just changed the MTF to Redline MT-90 at 38k miles. 1.9 Liters on the dot. There is a smoother transition between gears.
29 fl/lb torque on both bolts and a 15/16" socket.
be aware that the fluid will spill out very fast and you could get fluid all over the ground.
(happened to me) :clap:
I would recommend this. 7.95 / Qt at Summit Racing.
Does anyone have experience with Royal Purple Max-Gear?
They make it in 75W-90 and it's API certification is GL-5. Our manual states that for an xA, we should use 2.0 quarts of 75W-90, GL-4 or GL-5. Royal Purple's website also says that it is not corrosive to soft metals, so it should be safe to use in that regard.
Anyhow, opinions?
Anyhow, opinions?
I switched to Mobil-1 Synthetic Gear oil at 20,000 Miles, After about 5,000 miles I started grinding into 3rd gear whenever the transmission got hot. I usualy race the xB on the weekends, so that might have also caused the problem. I've used Mobil-1 in the engine also (5W-30) And I noticed more engine noise at idle than normal. I switched back to Castol Synthetic Blend (5W-30) and it runs way better than the Mobil-1 in my opinion. So now I'm going to try the Motul Technosynthse 75W-90 Gear oil.
My recomendations:
-Engine oil: Castrol Synthetic Blend 5W-30 (K&N Oil filter also)
- Gear oil: Anything but Mobil-1 (Maybe Motul Ask me in about a week!)
My recomendations:
