changing gear oil on 5spd question...
Old Aug 10, 2006 | 03:09 AM
  #81
TJ's Avatar
TJ
You can switch it out the first day you get it back to your house.
Old Aug 10, 2006 | 04:47 AM
  #82
xnevergiveinx's Avatar
Originally Posted by djct_watt
OK. . . so at first I tried Mobil Synthetic 75w-90 gear oil. . . and man, were you guys right.
Man tranny had never shifted worse. I had to COMPLETELY rev match 2nd gear, otherwise it would grind. Shifting at redline from 1st gear required almost a 2 second wait for the revs to drop. HORRIBLE. If you drive hard, have driven hard, or plan to drive hard, stay AWAY from the Mobil gear oils. The biggest waste of money ever, and the worst gear scratching/grinding I've ever encountered. Furthermore, the shfiter felt as smooth as breaking chicken bones at the joint. EW!!!!! The only reason I used Mobil, was because it was all that was available at the time.
Now that I moved to SoCal, we have Superautobacs. Hello Redline!!!!! After about a day to break in the new oil, my tranny is as good as new. I can rush my 1-2 shift without so much as a squeek out of the transmission (not that rushing the shift is a good thing). My point? The redline helps the synchros DO THEIR JOB. Even for people who don't abuse the transmission, the tranny/syncros seems to need to work MUCH less to match the revs. With the Redline MT90, it just feels sooooo buttery smooth.
thats scary how big of a difference there is between 2 fluids. i'm guessing the redline oil has friction enhancers and the mobil does not.
can anyone explain what exactly friction enhacners are and what they do?
Old Aug 12, 2006 | 12:14 AM
  #83
vintage42's Avatar
Originally Posted by xnevergiveinx
...i'm guessing the redline oil has friction enhancers and the mobil does not... can anyone explain what exactly friction enhacners are and what they do?
"The synchronizer drives a cone shaped metal piece against the gear and starts the gear spinning."
http://www.innerauto.com/Automotive_..._Synchronizer/
There is a good explanation at http://members.***.net/elans4/Transmission.htm.
To synchronize, your shifter presses the inside of synchro ring 7 onto the cone 6 of the gear 5. This spins the new gear up or down to match the speed of the gear you are leaving.
The more friction there is between the synchronizer and the cone, the quicker the gear will spin up or down and synchronize with the next gear to make a smooth shift. But how can slippery oil be made to increase friction? There are additives that can do this without affecting the lubricating properties.
The synchronizer rings for each gear are made of brass, softer than steel in order to not damage the steel gears and also to be sacrificial. They are wearing parts. Speed shifting, hard downshifting, beating the synchros, poor oil, etc, will cause wear of the inside surface of synchro 7 and the brass teeth 4. Wear particles go into the oil and can be seen upon draining as a golden sheen.
Old Aug 12, 2006 | 12:47 AM
  #84
vintage42's Avatar
Originally Posted by vintage42
... Figure that by now any initial wearing in of gears, bearings and synchros has occured and is ready for draining. Manual transmissions do give off metallic sludge and whiskers in the normal course of operation (mostly collected on a drain plug magnet)....
Well, that's what I thought based on my vintage BMW motorcycle transmissions, but not so for the xB. When I changed to Redline MT-90 at 2500 miles, the OEM oil came out perfectly clean. Here's my DIY:
http://s49.photobucket.com/albums/f2...0Oil%20Change/
Old Aug 30, 2006 | 09:50 PM
  #85
joffficer's Avatar
Wouldn't the Redline 75W90NS be the best for the Xa/Xb transmissions? This is from Redline oil company:
75W90 NS
This GL-5-type geal oil doesn't contain the friction modifiers for limited-slip hypoid differentials. This makes the transmission synchronizers come to equal speeds more quickly, allowing faster shifting and much easier low-temperature shifting.
I noticed a lot of people using the MT-90, but doesn't this one sound better?
BTW... I have two quarts of Mobile 1 that will have to find a new home! Thanks, for the help!!
Old Aug 31, 2006 | 01:55 PM
  #86
HeathenBrewing's Avatar
I am assuming it is GL4?
I have been to almost EVERY auto parts store trying to score some GL4...impossible.
Old Aug 31, 2006 | 04:40 PM
  #87
joffficer's Avatar
no... like it says, it's GL-5. The manual for my Xb says I can use either 4or5, though.
Old Aug 31, 2006 | 06:56 PM
  #88
So the Redline GL5 contains the friction modifiers?
Old Aug 31, 2006 | 09:42 PM
  #89
vintage42's Avatar
I haven't looked the Redline site for awhile, but I think the MT-90 is GL-4 and the other is GL-5, the GL-4 has friction modifiers and the other one probably as well.
GL-5 contains extreme pressure sulfur additives and was orginally designed for hypoid gear applications like differentials. The sulfur apparently can react with the yellow metal synchronizers in transmissions and shorten their life (brass is made with copper, which could combine with sulfur to make copper sulfate, a patina which would soften the surface of the synchronizers). Thus some transmissions specify the use of GL-4, while for others GL-5 is not a problem.
Old Sep 3, 2006 | 07:30 PM
  #90
joffficer's Avatar
"This GL-5-type geal oil doesn't contain the friction modifiers for limited-slip hypoid differentials. This makes the transmission synchronizers come to equal speeds more quickly, allowing faster shifting and much easier low-temperature shifting. "
This is right from the Redline site for the 75W90 NS. Am I missing something? It sounds like it's made for transmissions that are synchronized (just about anything built since 1951). Are toyota's (scion) syncros made differently or of unique metals?
Old Sep 8, 2006 | 01:11 AM
  #91
Jan06xB's Avatar
be careful - limited slip differentials are different than transmission syncros - diferentials have clutch surfaces.
Old Sep 8, 2006 | 01:25 AM
  #92
joffficer's Avatar
Right... that's`why I thought this would be better for our tranmissions. We don't need the extra friction modifier's that the MT90 has.
Old Sep 8, 2006 | 09:53 PM
  #93
vintage42's Avatar
... for the 75W90 NS. Am I missing something? It sounds like it's made for transmissions that are synchronized...
From http://www.redlineoil.com/products_gearlubricants.asp it appears that the 75W90 NS is a GL-5 (sulfurous) dual-use differential oil, made without the slippery-type friction modifiers that are best for differentials, so it can also work in transmissions.
75W90 NS is a gear oil for differentials, and transmissions that have no brass and can tolerate the sulfur of GL-5:
"Red Line manufactures gear oils which can be used in limited-slip differentials without the use of additional friction modifiers... This GL-5-type geal oil doesn't contain the friction modifiers for limited-slip hypoid differentials. This makes the transmission synchronizers come to equal speeds more quickly, allowing faster shifting and much easier low-temperature shifting. Can also be used in racing limited-slip differentials where weak spring design causes too much wheel spin."
And MT-90 is a gear oil for transmissions only, especially those with brass synchros that cannot tolerate the sulfur in GL-5 oil:
"Popular in Nissan, Toyota and Mazda manual transmissions and transaxles... this is a 75W90 GL-4 Gear Oil... Red Line Oil's MTL and MT-90 are designed to provide excellent protection and improved shiftability for manual transmissions and transaxles... They have the appropriate coefficient of friction for most manual transmission synchronizers (many gear oils... are too slippery for proper synchro engagement).
Old Jan 15, 2010 | 10:26 PM
  #94
Super-Stormtrooper07's Avatar
Originally Posted by TJ
Just changed the MTF to Redline MT-90 at 38k miles. 1.9 Liters on the dot. There is a smoother transition between gears.
29 fl/lb torque on both bolts and a 15/16" socket.
be aware that the fluid will spill out very fast and you could get fluid all over the ground.
(happened to me)
I would recommend this. 7.95 / Qt at Summit Racing.
I know your post is about 5 years old, but looks like price went up to $12.49 per/quart!
Check it: http://www.summitracing.com/parts/RED-50304/
.... potentially a higher demand on the product!
Old Jan 15, 2010 | 10:36 PM
  #95
SquallLHeart's Avatar
it's not just demand that caused the price increase..
it's the economy, oil prices in general.. and inflation.
Old Jan 16, 2010 | 02:09 AM
  #96
yes.. yes, many potential variables , supply, etc. etc.
Well, considering this is the internet, its all about finding the product you want for the absolute lowest prices.. absolute! You don't want any one person making tooooo much profit
Looks like a dude on Amazon sell it for $11.49 + shipping:
http://www.amazon.com/Red-Line-50304.../dp/B000CPCBEQ
.... the search continues
Old Jan 16, 2010 | 03:30 AM
  #97
a bit less: $9.95 + shipping:
http://www.racerpartswholesale.com/p...nsmission_Lube
06ScionTc5sp1
9
Oct 16, 2020 01:18 AM
archael666
Mar 19, 2019 11:52 PM
awdmofo
Feb 8, 2016 05:58 AM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
c_dog
40
Feb 2, 2005 12:08 PM
