Corrosion on Positive Terminal
Old Apr 25, 2012 | 12:34 AM
LanceC85's Avatar
Default Corrosion on Positive Terminal
So I went to clean the corrosion off of my positive terminal today. Which I still haven't figured out why it is so corroded. Anyways; I clean everything with a wire brush/baking soda etc. In the process I break the bolt that holds the terminal on the post. So i go get a new bolt & hook it up in the parking lot. I had some battery terminal protectant that i sprayed on as well. Go to start it up and I noticed right way it was sluggish/idled odd it was rough. I took the posts back off made sure everything was ok etc. Then i noticed the VSC TRAC WARNING lights on. So i went to have the battery & alternator tested. They are 100% fine. I did nothing else to my car...what would cause this to happen out of the blue? 2005 scion xB. Everything was running smooth until i cleaned the corrosion off.
I've been reading about this problem, but no none seems to have the rough Idle I have...I do have a fujita f5 cold air intake aswell..going to advanced auto to get the obd read tonight...
Old Apr 25, 2012 | 12:38 AM
Vulkinator's Avatar
After disconnecting the battery the car has to relearn some things and will idle funny for a few minutes just let is sit for a while and take it out for an easy drive. If it feels like it may stall while stopped just give it a little gas to bring up the rpm's
Old Apr 25, 2012 | 12:43 AM
LanceC85's Avatar
how long would it take to "straighten" up per say?
Old Apr 25, 2012 | 12:53 AM
Tomas's Avatar
Admin Emeritus
Takes about two "drive cycles" which are essentially cold start, some idle time, some start-stop-shift city driving and at least some sustained high speed cruise - as on a highway. A couple of complete cycles like that (maybe a half hour's driving), driving as you normally would, should get your patterns learned.
Old Apr 25, 2012 | 01:34 AM
LanceC85's Avatar
or it could be p0172 (Fuel System Too Rich "Bank 1") at least that's what the diagnostic says...Apparently some of the corrosion from the terminal that i was cleaning must have gotten to a sensor somehow? Is it possible that the sensor hasn't failed and just needs cleaned? The sensor O'reilly auto parts quoted me for is $150...any ideas where the HO2S sensor(s) are?
Old Apr 25, 2012 | 05:07 AM
Tomas's Avatar
Admin Emeritus
Your Scion's black box actually could be running the engine a bit rich until it learns the specifics of your exact engine by being driven.
Whenever power is removed it resets itself back to the original factory settings until it re-learns what it needs to modify for your particular engine and driving style.
You may just have a unit that was reset and will re-learn, or you may have a problem that needs looking at.
If it were mine (it's not) I would give it a chance to learn, and if it doesn't, THEN I'd take a look at the sensors in the exhaust...
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
knuckleheadjcz
Dec 24, 2015 09:07 AM
MeDizzy
Oct 8, 2015 03:31 PM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
