What do I know about diamonds. Don't they come from Antwerp?
Apparently they come from Taiwan and are right under that plastic engine cover of the VVT-i
Here is what I used to polish the valve cover
400 grit and steel wire bit with the Dremel - 800 grit - 1000 grit - 2000 grit and then the polishing kit for the drill
Here is dirty diamond
And blammo, or err blingo
Here are some other pics
[/img]
[/img]
Let's see, 8:30 - 12:00 and one LARGE pot of coffee. I tryed to be pretty timid with the dremel bit, sos not to scratch the shiznit out of it. I'm happy. I went to wash the car and had the hood up, just cleaning a bit and the people from the other wash stalls were peaking over droolin. Hehehe
I want to give props to Agent47 for posting this little scion-secret first
https://www.scionlife.com/forums/vie...ed+valve+cover
Once you have it on and drive a week or so you will need to go back and clean it again with neverdull.......and then the endless cycle of polishing will go on and on........I do mine about once a month and it cleans up in about 30 minutes good as new.
high heat clear will just crack in about a week.......been there done that...then you gotta sand it all back off and start over....really it is easy to maintain,I do it about every other car wash
viciouzgamer
03-27-2015 12:16 AM
MrPay84
Regional - Great Lakes
03-09-2015 04:39 PM
