250HP!!!
Old Jan 18, 2013 | 06:46 AM
ants07tC's Avatar
Default 250HP!!!
hey guys i guess would be for the experienced tuner heads out there.... how could i make my tC push around 250hp? its a automatic and i kind of want it to be all motor for the mean time but i was also considering getting a supercharger for it cause im not a big fan of turbos in an automatic but i could be wrong.... please any help would help!
Thanks from a fellow tC owner,
Old Jan 18, 2013 | 01:18 PM
draxcaliber's Avatar
You will spend 10k to maybe get 250 whp all motor.
You could maybe do it for a little less with a supercharger, but they're very unreliable trying to get that much power out of it.
It is a sure thing with any turbo kit. Turbo's are great, why do you not like them?
Old Jan 18, 2013 | 01:26 PM
ants07tC's Avatar
Not for a automatic I feel like you don't get the full use compared to a standard... But that's my opinion what you think?
Old Jan 18, 2013 | 01:46 PM
TheQuietThings's Avatar
You will need to explain this further for it to make sense. Why wouldnt you get the full benefit of a turbo on an automatic transmission car?
IMO depending on the setup/size/tune a turbo car will run just as well as a SC or an NA car.
Old Jan 18, 2013 | 03:43 PM
BadDudeTC3's Avatar
My first turbo kit was a turbotoyotas kit and dyno'd at 244 whp at 7 psi with stock motor & stock tranny and the car felt & ran beautifully.
Old Jan 18, 2013 | 04:17 PM
the biggest drawbacks to turbo'ing an auto tC is the life expectency can drop and it might need some fortifying to take that much power depending on your driving habits. You should atleast get a transmission cooler.
but the auto has some advantages such as longer gearing so you stay in gear in boost longer, and boost pressure doesn't drop between upshifts because you never close the throttle.
Old Jan 18, 2013 | 09:18 PM
ants07tC's Avatar
True bro true I'm just asking around so I know what to do
Old Jan 19, 2013 | 12:40 AM
tCb00b's Avatar
Sell it and buy something with 250hp? Why that number? I'm s/c 5spd at 215 to the wheels. Stock boost (~7psi), Dezod green header, trd muffler. You know once you're at 250hp you'll want more. Start saving and go turbo. My s/c has been flawless the past 50k+ miles but it probably wouldn't live up to your power expectations. That's why I suggest turbo or different car.
Old Jan 19, 2013 | 02:30 AM
SonicDRKNITE23's Avatar
ants07tc im in the same situation as you. there are threads i have read on turbos out there, that go great with the car but cant really expect much on auto. I have been debating on s/c or turbo.. but one things for sure, once you get where you want in power.. your gonna want that extra more.
Old Jan 19, 2013 | 02:41 AM
ants07tC's Avatar
True but I would only want more power if I had a standard I just want a fast auto
Old Apr 17, 2013 | 07:34 PM
roadrunnergt's Avatar
Turbo it
Old Apr 22, 2013 | 12:44 PM
etoomey3's Avatar
Turbo! My tC made 253whp Turbonetics kit on 7psi with a stock engine, open DP and e-manage. Runs great. With your automatic, I'd use a trans cooler to start and see if it holds up. You should be able to make 250hp no problem, just keep an eye on that trans.
CXTKRS1
Oct 27, 2011 05:18 AM
WytonWyt
Aug 9, 2010 03:25 AM
3min3m2
31
Dec 23, 2009 12:16 AM
scblackbox
18
Aug 15, 2009 04:10 AM
Buebie
Regional - North
May 1, 2009 04:02 AM
