The COMPREHENSIVE thread on NST (NonStopTuning) Pulleys
ok so i bought a used NST crank pulley from a scion owner,i seen that it was smaller than the OEM size..i install it and next day the belt ripped..i recently bought the k060747 from NAPA..and then the belt was too short..is it that the crank pulley comes diffrent when you buy the set of 3?(smaller than the OEM size)or when you buy the crank pulley itself,it comes OEM size and you dont need a new belt?
If you have an 05-06 tC, you should be able to use K060747. You can also try K060750... just slightly longer, as you can see from the part number. This same belt should work whether you are using the underdrive crank pulley alone, or along with our overdrive alternator pulley.
If you have an 07-10 model, you should be able to use K060739 or K060740. This same belt should work like I said above.
It is important to try to use Gates belts, as they are most true to size.
Good luck and have fun with all your projects!
Just read all the user reviews and feedback from all of our customers, in the previous pages of this thread.
installed the set last week with a friend. took us about 3 hours start to finish. impressed with the quality. very happy with the results. Revs a lot quicker, rips through first and second. definitely worth the money. props to NST.
Install tip: since we didn't have air tools, once we got the alternator off, we took it to Autozone. they took off the old pulley and put on the new one for free. took about 2 min.
Hey man i just ordered a CRlite for my TC and the lite crank pulley for my girlfriend's xa. the pulleys look awesome, great quality. i tried to install mine last night but unfortunately as everyone has said hand tools just dont cut it. i couldnt keep the pulley still and i dont have air tools so i am taking it over to jhonny tran at Overdrive in conroe for them to put it on for me today. By the way the shipping was incredibly fast, i ordered them on friday at the same time i ordered pads from dezod. your pulleys got hear on monday and i still havent gotten the pads. thanks again man.
Be sure to post your reviews with us after you and your girlfriend install your pulleys and go for a few test drives.
Thanks again!
Hey got the pulley installed. It is by far the best bolt-on I have added so far. Not only is the car a lot more responsive but it idles so smoothly now I can barely tell it is running. This part was worth it just to smooth up idle. Great part I would recommend it to anyone. Thanks NST
https://www.scionlife.com/forums/sho...NST+pulley+diy
And yes, NST pulleys can be combined with other brands.
Mike always answers this
to answer your question 2beturbod....the answer is yes, according to NST, adding the whole 3 pulley kit (water, alt, crank) will give u the best results, having just 1 or 2 is still good but having 3 is the best combination and the best results...just common sense, would you want 1 cookie or 3 cookies? what is better?
but it's all good i'll help him out since he's such a nice guy
Wow, I can't believe I remembered my login info for this site (after the 4th try lol) I haven't been on in about a year. I just wanted to come on here and let you know I will be ordering the entire set of pulleys! I have never even considered going with another brand for these
