DIY: oil change W/ PICS!!
Old Jun 16, 2006 | 10:49 AM
  #41
2_tC's Avatar
Get the drain plug washers from the dealership parts counter. They only cost like 25 cents. I use OEM Toyota oil filters, they cost me around 4 bucks each if you buy 2 or more.
Old Jun 16, 2006 | 04:19 PM
  #42
R2D2's Avatar
Make sure the oil filter you use = p/n 90915-YZZF1
That is unless your going TRD filter which than = p/n PTR14-00000-06
via trdsparks or mcgeorges
in anycase, these items are highly recommended (haven't tried the TRD filter yet),
and yes I've been using the insanely expensive redline oil as well SquallLHeart so ur not along when it comes to spending insane amounts of $ for just motor oil (where in the bay and for how much did you get them for?).
On a side note, when is it suggested that we change viscosity oils?
I've been on 5w-30 synthetic since birth .
Old Jun 16, 2006 | 07:29 PM
  #43
Scion_shift's Avatar
castrol sucks, i out that in my type-r when i had it and i sluged up my motor. i recommend mobil 1 and a mobil 1 filter
Old Jun 16, 2006 | 07:48 PM
  #44
Skeorx13's Avatar
(shrugs) Hmm, I just get mine done by a shop nearby. I get it for like $15-$20. It's faster and I don't get dirty.
Old Jun 16, 2006 | 07:59 PM
  #45
engifineer's Avatar
As far as changing viscosities, if you are staying NA I say never change it. I have seen many rattling toyotas fixed by switching BACK to 5w30
Old Jun 17, 2006 | 06:08 AM
  #46
girl
Old Jun 17, 2006 | 06:19 AM
  #47
asthmatic's Avatar
^haha
do we have to get the car flushed if we switch to synthetic oil? including transmission fluid?
Old Jun 17, 2006 | 06:35 AM
  #48
not neccessary no. any different oil will eventually come ot in oil changes. no big deal
Old Jun 18, 2006 | 03:09 AM
  #49
ericsscion's Avatar
great write up... i might try it out tommorow
Old Jul 2, 2006 | 08:06 PM
  #50
brownbanana's Avatar
just changed my oil again this morning and was going to replace the drain plug washer for the first time (3rd oil change) but couldn't get it off was stuck on the oil pan. Any tips for removing that sucker?
Old Jul 2, 2006 | 09:23 PM
  #51
SquallLHeart's Avatar
err.. flathead screwdriver?
Old Jul 3, 2006 | 09:12 PM
  #52
richardsayzz's Avatar
Originally Posted by SSQ
Have you always been using M1 in your car? How does tC like it? I'm about to switch to it after this run of GTX for breaking in.
One thing I would like to add. Don't take the oil cap completely off. Take it off, but lay it over the hole at an angle. helps minimizing dust and stuff from going in.
And remember to replace the crush washer once in a while
whats a crush washer?
EDIT: woops i just read through this whole thread and found out...
Old Aug 1, 2006 | 04:19 AM
  #53
Brakefade's Avatar
Just some additional info:
Torque for the oil pan drain plug is 30 ft-lbf
Torque for the oil filter is 9.5 ft-lbf, or screw it on until the gasket makes contact with the seat, then tighten another 3/4 of a turn.
Old Aug 1, 2006 | 04:26 PM
  #54
Tranman's Avatar
Anyone know what oil filter wrench size to use?
Old Aug 1, 2006 | 04:31 PM
  #55
i used the one thats like a wrench, like this
Old Aug 1, 2006 | 05:13 PM
  #56
BigMURR's Avatar
Or you can just go to autozone and pick up any socket wrench attachment for oil filters... thats what I have.
my only question with this write up is: is heineken the prefered beer for the oil change? Would it be alright if I substitute bud light? Would there be any negative effects with the change?
Old Aug 1, 2006 | 06:04 PM
  #57
Spect2K3's Avatar
I use the filter wrench with the socket attachment on bottom. It looks to me like it is the smallest filter wrench around
Old Aug 3, 2006 | 02:05 AM
  #58
fm_tc_cruizer's Avatar
Originally Posted by engifineer
For those that have not done it, you should add to NEVER tighten the filter with the filter wrench. Tighten it hand tight only.
Why the NEVER tighten it with a wrench? I'm just wondering cuz I used to have a tercel ( ). Changed the oil myself every time and used to tighten with the oil wrench. Sucka ran 230,000 miles and was still kickin'. That's why I buy japanese.
Anyway, I'm sure there must be a good reason because 2 people said to only tighten by hand.
Old Aug 3, 2006 | 02:56 AM
  #59
when you put it on.. TIGHTEN BY HAND..
when the engine starts running and heating up.. it's gonna expand and then make a pretty hard seal... the wrench is only used to help remove and crack open the oil filter when it's been thru all that.. and for the most part.. is damn tough sometimes..
imagine how hard it'd be if you tightened it with a wrench..... yeah.... i don't think you'll want to kill yourself trying to remove the used oil filter.
Old Aug 3, 2006 | 10:18 PM
  #60
3min3m2's Avatar
Your car would gain 7 whp, and 5 lb-ft of torque
