nitrous help
Old Jul 12, 2009 | 06:23 PM
krazyjvilled's Avatar
Default nitrous help
have triple threat kit coming in for my auto... plan on using a 65 shot.
was wondering if anyone knew the shift times of an auto at WOT... i believe at WOT it will still shift right at redline or close to it...
i have a window switch so im trying to find the best rpm range for performance but as well as keeping it safe...
was thinking 2nd-4th gear... 2500 rpm- 5700 rpm... we redline at 6200 rpm i believe...
anyone have any info that would help me with this? thanks
Old Jul 12, 2009 | 09:34 PM
Iowa_TC1's Avatar
Default Re: nitrous help
I have a zex kit with a window switch that skip 1st gear and comes on at 3400 and shut off at 6000 RPM. I wouldn't let the nitrous stay on past 6000 just to be safe. 3400-4000 RPM is a good rpm for it to come on because when you shift you will already be in that RPM range or higher so there's no since in having it come on at 2500.
Let me know if you have any other questions
Old Jul 12, 2009 | 09:52 PM
ok thanks, that makes sense about starting it a bit higher in the RPM range... however, i have an auto, do you know if at WOT if it shifts at redline still?
what happens if it shifts and its still spraying, does that spell automatic doom to my engine?
i will probably start it out at 3000 rpm so that it kicks in right away in 2nd... i dont want to keep it on until 6000 incase the auto shifts a bit sooner... would 5700 be safe for an auto you think?
Old Jul 12, 2009 | 09:58 PM
2beturbod's Avatar
Do you really need to have a window switch for an Auto? I mean I am only using mine during racing so I dont want it to constantly spray. Is my thinking right or wrong? I am a complete nemb at this. Sorry to threadjack but your talking about nitrous and have an auto like me.
Old Jul 12, 2009 | 10:13 PM
XIEmperorIX's Avatar
Do you plan on getting yor car tuned also? I rembmer hearing it isn't save to run higher than a 45 shot without a tune? I could be wrong though
Old Jul 12, 2009 | 10:17 PM
the guy i know who is installing it said he will tune it... i believe you just have to make sure enough fuel is being pumped with the shot since it is a wet kit..
does anyone know if auto's shift at redline when WOT?
Old Jul 13, 2009 | 04:22 AM
Iowa_TC1's Avatar
You still should get a window switch to be safe automatic or not. If you only running a 55hp shot you don't need to tune it, but anything higher you should. If you do tune it you will have to get EMS to.
Old Jul 13, 2009 | 06:21 AM
i did get a window switch... and i plan on running a 65 shot... i have asked a few very knowledgeable people on nitrous and they said i do not need any engine management system to tune it...
still waiting if anyone knows if at WOT an auto shifts at redline?
Old Jul 13, 2009 | 12:37 PM
cburglb34's Avatar
i cant answer your wot question but it really doesnt matter cuz the trans shifts way before fuel cut its not redline u have to worry about when spraying its fuel cut so at the very end of redline......and as far as spraying while shifting....on autos its fine since u never let off the gas pedal...the reason why manuals cant spray while shifting is because when u let off the gas nitrous will not be sucked into the intake and will puddle...
Old Jul 13, 2009 | 05:54 PM
ooo... ok man that makes perfect sense and really helps me a ton... i appreciate it...
i did not know you could be spraying while the auto shifts... good to know...
VitaminE
Mar 24, 2015 03:36 PM
yhwhdesign
Mar 7, 2015 02:01 AM
spawnconnery
Dec 18, 2014 08:38 PM
aarontrini85
37
Jan 24, 2009 03:21 AM
aarontrini85
24
Feb 5, 2005 04:29 PM
