Pic Request: Battery Negative Cable?
Hey guys, I ran into a little problem with my memory..
After a long day of changing out my clutch and flywheel.. I forgot where the END of the negative battery cable goes to.. one end goes to the battery, and the other end goes to a ground.
And with so much things in my mind during the install, I run into this little problem. I temporarily bolted the end of the cable onto the slave cylinder to test and see if my clutch chatters.
If anyone is kind enough to show me a picture of where the negative ground cable is bolted onto.. that would be great.
Thanks in advance.
____
Thanks in advance.
____
thanks.. but i dont see where its connected to. I know the negative cable is the gray cable and it's obvious to me where it goes on the battery.. but I need a pic of the end of that cable to where it's mounted to, which ground? is it located underneath the battery?
a little off topic, but i went under my car today and notice there are vents under the transmission and air is coming out of it.. i thought it was a leak, but im thinking its there for a reason?
Have you ever roasted your clutch? That's probably where the smell is vented from.
My car is parked outside, so I can't look, but i'd like to know the answer to the original question as well.
I can’t figure this out either.
One to the Battery but forgot where other hooks to. I have the small one underneath the Battery tray.
And help or pics please
____
Administrator
Administrator
All I can find is this Parts Diagram: Scion TOYOTA OEM 05-10 tC Battery-Negative Cable 82123-21080
Perhaps a 05-10 tC Owner can Upload a real Pic of the Negative Battery Cable
where it's connected to underneath?
MR LUV
__________________
Here's a couple of pics:
Here's the battery tray from above. Note one leg of the negative battery cable lug connects to an angle bracket, just beneath the battery tray.
Here's a shot from below. Note the negative battery cable lug in the upper right corner.
Here's a shot of the second negative battery cable lug. It bolts to the aluminum transmission housing which is adjacent to the starter housing in the upper left corner. Sorry for the fuzzy pic.
Jaci121
02-24-2017 10:33 PM
icestorm
Scion tC 1G ICE & Interior
06-23-2014 01:41 AM
muuunkeeyy
05-30-2013 01:00 AM
