THE Short Throw Shifter Thread
Old Sep 28, 2007 | 02:47 AM
  #361
WeSellCarParts's Avatar
theres multiple pictures of the megan from customers in my for sale thread
Old Oct 4, 2007 | 05:51 PM
  #362
Battossai's Avatar
I know this is an old thread - but - am I hearing the TWM stage 2 is the best - I've tried the TRD (not impressed) and the perrin - is not really adjustable - they both sat at stock hieght - and the perrin's throws are actually worse than the TRD
Old Oct 8, 2007 | 04:35 AM
  #363
07_Tc_blacksandpearl's Avatar
Im going to get the TWM stage 2 shifter. Who should I go with for the shifter and cable/cage bushings? What brands for the cable/cage bushings?
Old Oct 11, 2007 | 03:17 AM
  #364
Sleek98's Avatar
I have the Dr I. short throw and man it is awesome. 50% reduction and its 2 inches shorter. I love the feel of it.
Old Oct 17, 2007 | 12:15 AM
  #365
crazycornuts18's Avatar
ok i bought the mgean racing short throw shifter and it came with these 4 purple metal pieces what are these? ive looked over the forum
Old Oct 22, 2007 | 05:05 AM
  #366
SoccerBoy_AP's Avatar
I did a search on a few pages of this post and didn't find the Megan Short Throw Shifter. So I'm just dropping in the info...
The Short Shifter is made with high strength billet steel and nickel plated for ultra low friction and corrosion resistance. The throw is reduced up to 40%, and shift **** height is reduced by 1 to 3 inches depending on the model. These shifters provide a more precise shift and allows for quicker shifting without drastically changing the overall driving experience. They have been designed specifically for the more aggressive tuner who demands the most extreme shifter in terms of both looks and performance.
Spec:
- Reduce at least 1" from the height of the stock shifter.
- Easy installation, reduce shift throw distance
- Each shifter comes with one year limited warranty
I found it at 59$ from dezod.com. I will be installing it this week. From reading other installs this one is a step ahead... since it includes the sealing rings that are such a pain to remove... I mean having to take a dremel to it!?
But there it is!
Old Oct 23, 2007 | 04:10 AM
  #367
Shift_N_Red's Avatar
you know here is my $.02 after looking at all the options and seeing who has what and how it looks etc etc.. I have decided that I will be picking up the whole cage from Dr. I ..... its worth the money to have it all done in one swoop.... plus.. its the easiest of the swaps.... and Im a lazy _____......
Old Oct 23, 2007 | 07:37 PM
  #368
engifineer's Avatar
What I like about the doc I is that it is made from a stock shifter with the pivot ball relocated and the height reduction made. I have heard that some of the other aftermarket units have had issues with sloppy shifts due to the ball being the wrong size. Issues you wont find with a unit made from the stock shifter.
And you dont need a dremel to remove anything. When I got mine from Doc, he didnt have the push washers with them. I got a replacement for about 30 cents at True Value and it took about 30 seconds to remove the old one with a screwdriver.
Old Oct 24, 2007 | 11:53 AM
  #369
We have sold over 200 Megan Racing. They sell extremely well. Some people use the cage risers and others do not.. Overall well worth it and looks great after install!
Old Oct 24, 2007 | 01:01 PM
  #370
ditto!
<--- installed with risers
unfortunately broke my shifter handle and had to use the megan one, not that there is anything wrong with it, I just prefer the OBX one.
Old Oct 28, 2007 | 08:48 AM
  #371
whiteTeaseC's Avatar
Im leaning towards the B&M SS. What do the bushings do anyway? does it make shift smooth? if so does the B&M come with bushings?
what im looking for pretty much is: not too much height drop, shorter shift between gears, and definitely want them to be smooth!
which ss do u guys suggest that have those ^ qualities for a good price?
Old Oct 28, 2007 | 05:29 PM
  #372
2fast4you's Avatar
Team ScionTific
Dr. Isotope GearSwitcher. Shortest throws, custom height, and lowest price. He uses the OEM shifter to make his short shifter, so they are smoother, more durable, and fit better than other aftermarket SS.
Old Oct 28, 2007 | 05:33 PM
  #373
Enrique9876's Avatar
hehe i sold my shifter to dr. isotope ... it kinda brings a tear to my eyes... thinking that my stock shifter has found a home...
Old Oct 28, 2007 | 07:59 PM
  #374
CuRiOuSfIsH's Avatar
I have the B&M STS. THe bushings are there to keep things from moving when the driver is in the mood to shift hard. Dont know if it smooths the shifts but I guess it could b/c some of the parts are not all over the place. Yes, the B&M comes with bushings, some ppl call them cage risers. The B&M does drop the height a little, not very noticeable, but I have no regrets w/ it. It will seem somewhat stiff at first but give it some time and it will smoothen out.
Old Oct 28, 2007 | 09:59 PM
  #375
thanks for your input.
uhmm what about the CC short shifter, does it come with bushings?
Old Oct 29, 2007 | 01:48 AM
  #376
I believe CC does, and so does Megan Racing. Both are cheaper than B&M but lower the height a lot more.
Old Oct 30, 2007 | 07:20 AM
  #377
is it true that have a ss wears out the tranny a lot quicker?
Old Oct 30, 2007 | 11:29 AM
  #378
tCizzler's Avatar
lol!! No, thats false
Who told you that?
Old Oct 30, 2007 | 03:22 PM
  #379
thats one of those things that you can almost see how it would make sense... but when you get down to it... its just not possible.
  #380
engifineer's Avatar
In order to reduce throw past a certain amount or to reduce throw without reducing overall height, you HAVE to use cage risers. The idea is to move the pivot ball up on the shifter, meaning the top of the shifter moves less when you shift. This effectively sets the shifter lower into the cage. At a point, it would hit the floor without cage risers.
Bushings are normally referring to cable bushings. For the doc iso, he makes replacements for the rubber cable bushings out of delrin. While this tranfers a little more vibration to the shifter (not really that noticeable when you grab it) it also makes for crisper shifts by taking the spongey feel out of them.
