TC Super charger in the next 2 weeks??????Repost
Old Aug 10, 2005 | 06:27 PM
  #81
engifineer's Avatar
I have been told that they will not do it. But I havent really dug into it to find out. I seriously doubt they will though. They do not do it for other options.
Old Aug 10, 2005 | 06:44 PM
  #82
JakeMafia's Avatar
Ya your most likely right, i just want to think that they will do it. I might just be spending that 3500, but i have to see a dyno first
Old Aug 10, 2005 | 06:46 PM
  #83
jmiller20874's Avatar
Just go through another bank, preferrably through a credit union. Maybe you'll end up with a payment close to your original.
Old Aug 12, 2005 | 12:34 PM
  #84
Scion-ce's Avatar
Ok....so if the supercharger is supposed to come out in september, why has TRD not released ANY info on it? If TRD hopes to salvage the loss of customers to the people that have gone the turbo route, they will make it at least 220hp at the crank. The only reason I am getting the supercharger is because my dumb@$$ got the 6yr./100,000mile extended warranty
Old Aug 12, 2005 | 01:30 PM
  #85
RollaS's Avatar
they have released info.....the part numbers are out, the price is out, the scion brochure has had a whole article about the tC supercharger. I went through this whole deal when TRD was making a supercharger for my corolla. There wasn't much info about it until it was released.
Old Aug 12, 2005 | 01:34 PM
  #86
Scion-ce's Avatar
they could at least post the gains. TRDsparks has posted 25% increase which is 40 hp, but that does not make sense. IT CAN"T BE TRUE!!!!!!!!!!!!
Old Aug 12, 2005 | 02:19 PM
  #87
dachmo's Avatar
If we assume that the boost will be about 7lbs, that is approximately a 50% increase in air, so at 100% efficiency, would that not make a 50% increase in power? but if it's only making 25% more power (according to TRDSPARKS) then the supercharger is not efficient at all. Is it normal for a supercharger to be that inefficient?
Thanks
Dante
Old Aug 12, 2005 | 02:40 PM
  #88
BrEaK_AwaY's Avatar
we will see when it comes out. i will have it by next year with out a doubt, reguardless if it is 200whp (i hope), or 200 to the crank. i need a show car, not a race car... tho the speed is nice =]
Old Aug 12, 2005 | 03:34 PM
  #89
JakeMafia's Avatar
Ok well even if the SC only added around 40 to 50 hp, wouldnt that still be a huge jump, If you look at the chevy cobalt, that only has 205 hp on a 2.0l engine, and they run 14.4 1/4 and 5.9 0- 60, that isnt bad at all, but maybe chevy is really underrating the cobalt? dont know, but i am really hoping for 210-215 whp
Old Aug 12, 2005 | 04:28 PM
  #90
dachmo's Avatar
yes....205 hp but 12lbs of boost
Old Aug 12, 2005 | 06:05 PM
  #91
JakeMafia's Avatar
Does that boost number matter, the cobalt is still only running 205 hp, so if we were running 6 lbs of boost and making 205 hp, whats the difference?
Old Aug 12, 2005 | 06:14 PM
  #92
aarontrini85's Avatar
im not doubting you but at the last import wars i went to in wi there were 2 cobalt ss's there and they both were running 15.1 and 15.0 but it was also well over 100 degress and my friends gtp was barily beating my tc so i could just be the heat messes up f/i cars alot never mind im done talking sorry should have thought of that before i started typing lol
  #93
05-RS1's Avatar
ok i jus got back from my dealership, and i was talkin to one of the scion salesman that also owned a tc. he told me the complete opposite and he said that he HIGHLY DOUBTS that the supercharger will be released anytime soon. the only progress they made was a price and he told me $3200 for parts and install.
Old Aug 12, 2005 | 06:17 PM
  #94
BrEaK_AwaY's Avatar
the differance is, if tC's ran at 12psi, then we would have alot more hp than the colbalt
keep in mind, the higher the psi on a daily driver, the easier it is to put wear and tear on the car
Old Aug 12, 2005 | 06:54 PM
  #95
JakeMafia's Avatar
break away,
thats what i was saying, so if we only get around 205 hp, with 6 psi we should still run as close to or the same time as the cobalt ss,
But the other guy said the opposite, he said that the cobalt would still be faster than the tc cuz the ss is running 12 lbs of boost, even though the tc has 200 hp,
Old Aug 12, 2005 | 07:13 PM
  #96
BrEaK_AwaY's Avatar
ok, to sum it up
tc running on 6psi vs cobalt on 12 psi = same
tc running on 12 psi vs colbalt on 12 psi = tc owns
but if you get the trd sc, and it does run psi, and it does give 205 crank hp, you have to spend more money on pulleys, and other accessories to increase the boost to 12 psi
Old Aug 12, 2005 | 08:08 PM
  #97
JakeMafia's Avatar
Ya plus the cobal has the limited slip, that the tc so despretly needs
Old Aug 12, 2005 | 08:24 PM
  #98
freeflowing's Avatar
well we all might as well save our money for the engine thats coming if toyota is promising 250hp on the next version of the tc
Old Aug 12, 2005 | 08:38 PM
  #99
matty-tC's Avatar
Originally Posted by BrEaK_AwaY
ok, to sum it up
depends on the efficiency of the compressing device. you could run a 14b way out of its efficiency range and not get any good power but if you size the turbo right and have the right wheel it'll outmuscle a different car with a mismatched turbo at the same boost level.
apples vs. apples
Old Aug 12, 2005 | 08:39 PM
  #100
matty-tC's Avatar
if they're smart, they'll continue with the 2az-fe program and just have it boosted from the factory.
