tC Valve Lifters Order..
Old Aug 12, 2009 | 03:20 PM
streetracer99x's Avatar
Default tC Valve Lifters Order..
So I forgot to take the valve lifters out of the head before I turned over my block and they all fell out on the floor.
Anyone know the order they go in by chance?
______
Old Aug 13, 2009 | 01:39 AM
TcPrincess's Avatar
lifters? you mean the buckets? if so then you have to just put them all back and measure.
Old Aug 13, 2009 | 06:21 PM
i dont have the ablity to do that. does anyone have the number they go in please it would make life so much easier
Old Aug 14, 2009 | 02:36 AM
Windu's Avatar
Doesnt work that way. They are different thicknesses. Thats how you set valve lash. No two heads are the same.
Old Aug 14, 2009 | 02:46 AM
so do you think that could be my problem and preventing the crank from turning after a certian point
Old Aug 14, 2009 | 03:22 AM
Windu's Avatar
I doubt it, probably have the cam timing off a tooth.
Old Aug 14, 2009 | 03:45 AM
so if the timing is off a tooth that would prevent the crank from turning over after a certian point?
Old Aug 14, 2009 | 11:39 AM
BlackKnight's Avatar
Music City Scions
Are you assembling your engine or was there a problem with it?
I know how this is going to come off (I appoligize there is no way not to sound like a -ick.) but if you don't know what you are doing or are uncertain about something get the repair manual. Maybe someone on the site can help or get one from Toyota. Toyota is really expensive but would you want to take a chance and blow your engine? Explain what you are doing, if you changed parts explain that, and someone should be able to help you better figure out your issue.
Old Aug 14, 2009 | 03:07 PM
I take no offense at all. this is all a learn experiance to me. i was dumb on my part and forgot to take out the lifters in the order they where placed in. and i think the timming could have 180 itself so im going to try and take off the cams and the chain then crank it over with a wrench and see if it gets stuck or if it rolls the right way
Old Aug 14, 2009 | 03:16 PM
Music City Scions
Hopefully someone can hook you up with that portion of the manual. Even if you take it apart and put it back together it could still make too much difference and you would have to remeasure the clearance and adjust the shims accordingly.
Old Aug 14, 2009 | 03:22 PM
yeah i even went to the dealer and they didnt know what i was talking about if it doesnt work im just going to get another motor.. or sell this one..
Old Aug 14, 2009 | 08:40 PM
blackcherry07's Avatar
hey man i can sen you the engine section of the toyota repair manual in PDF.
just pm me your email.
Old Aug 14, 2009 | 09:19 PM
pm'ed
Old Aug 14, 2009 | 10:16 PM
e-mailed
Old Aug 15, 2009 | 03:52 AM
Music City Scions
That is what I am talking about! Hope everything works out once you get the manual it should explain exactly how to do everything. Does anyone have the engine section for the 07?
Old Aug 15, 2009 | 03:35 PM
pm me your email...
Old Feb 1, 2010 | 03:39 AM
Prophecy2k4's Avatar
Super old thread, but did you ever figure out an EASY way to go about it? I made the same mistake and hate how the service manual wants you to do this that and the other. The equation they give seems a little ridiculous....There has got to be a better way.
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
6885BLM8435
Aug 19, 2015 03:08 PM
rancur3p1c
Jul 12, 2015 07:59 PM
