Wheelhop
Old May 26, 2006 | 09:53 PM
zer0's Avatar
Gonna have to call em
Old May 26, 2006 | 10:00 PM
tom0613's Avatar
i belive zpi makes motor mount
Old May 26, 2006 | 10:01 PM
zer0's Avatar
Yea, but they are not out yet.
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
motor mounts are in final stages(from what i was told), pre-order ppl keep your eyes peeled
Old May 27, 2006 | 01:58 AM
raamaudio's Avatar
Stiffy's, etc are a better than a band aid but not the real cure.
If you can either let you car sit for a week or get some mounts from the wrecking yard, just the front, rear and dirvers side will do. you do as I have done on a few cars over the years.
Get some Devcon Flexane 80, remove those mounts(have to jack the engine up), clean, mask and fill with the Flexane, oven cure for 24 hours, let them sit for a week and room temp, install, done.
I removed all the factory counter weights(saved a few more pounds off the car) and have barely any added vibration at all and absolutely zero wheel hop, far less drivetrain ******(different terms can be used here) and much a more in control feeling entering and exiting corners now that the engine is not moving the suspension around.
$35 pint size two part kit is enough for two cars.
Rick
Old May 28, 2006 | 08:13 AM
soros151's Avatar
Rick
In what sport do you participate? Autocross?
Old May 28, 2006 | 08:36 AM
raamaudio's Avatar
Mainly autocross, I will drag race a few times and do some solo I and time trials as well as track days once the rest of the car is done(turbo system I am building).
On my last prodject car the, a turbo Matrix with 250WHP on the dyno the front wheels would move forward around two inches with the stock mounts and close to the same with a solid top mounted or front mounted torque "damper". That is alot of power being wasted twisting things so much to cause the wheels to be pushed that far out of their proper position.
Once the mounts were filled they would barely move at all.
Rick
Old May 28, 2006 | 11:23 PM
pryde's Avatar
From ZPI's AD... they make it seem like the install for their mounts wount be to difficult. I think they said there's 3 and you do em all indivually. Not sure if i believe em... course I have a tendancy to make a vry simple project way more difficilt then it needs to be
Old May 29, 2006 | 01:14 AM
raamaudio's Avatar
The front and drivers side are relatively easy, the front being very simple really.
The rear mount is a bit of a hassle I am sure, maybe more of a pain than led to believe but I did other things at the same time so hard for me to rate it on a scale.
Front, 1 out of 10
Side, 3 out of 10
Rear, from what I know which was not doing it seperately,
8 out of ten.
If you average the numbers this is a very easy job, taking individually, the rear may be a royal pain in the ****.
Again, I have not done it seperate so not able to know for sure but it was a hassle in what we were doing at the same time.
Rick
Old May 29, 2006 | 01:56 AM
soros151's Avatar
Can someone please do DIY to fill these motor mounts?
Old May 29, 2006 | 01:59 AM
pollup's Avatar
i honestly wouldnt change them unless your getting in there and doing yoru clutch and flywheel. to do those you unbolt the driver side of the engine and drop it down, then pry it to the side. you get easy access to that rear one that way.. the rest just fall into place after that. to do individually, holy cow, thats a job and a half.
Old May 30, 2006 | 02:01 AM
raamaudio's Avatar
Just to be sure I am clear on this, I did not mean that I did or suggest doing them individually, just that two of them are very easy to remove and install and the rear one is a bit of a pain in the ****
Soros,
Not sure what you are asking, DIY is do it yourself, what we are talking about. Please explain what you are after a bit more
Rick
Old May 30, 2006 | 02:23 AM
jwaggz82's Avatar
zpi said that installing the mounts should not be that hard. We might be able to use a jack and keep the engine in place - undo the mounts - jack the car up an inch - then put the new mounts on. ...we shall see.
Old May 30, 2006 | 02:28 AM
soros151's Avatar
I meant a How-to about filling the motor mounts with...whatever you fill it up with. lol, A how-to do that.
Old May 30, 2006 | 02:53 AM
zer0's Avatar
Im gonna try and fill just the front mount for now. Hopefully that calms down some of the lash..
Old May 30, 2006 | 05:09 AM
xnevergiveinx's Avatar
take pictures of the process
Old May 30, 2006 | 01:27 PM
toyota_scion_tc's Avatar
After I installed my TRD suspension and Ingalls "Stiffy" I have no wheel hop either but I still plan on mounts.
Old May 30, 2006 | 01:38 PM
zer0's Avatar
Filling mounts is pretty easy and straight forward.
http://www.2gnt.com/www/corbin/mount.html
http://importnut.net/motormount.htm
08superwhite
10
Jul 7, 2008 04:27 AM
TRDSilverTC
39
Jan 11, 2008 11:33 PM
jive_turkey
Jan 27, 2007 06:32 AM
Ryhian
Autosports & Technique
16
Sep 5, 2006 02:29 PM
