AEM F/IC Setup
Old Jan 1, 2009 | 05:00 PM
  #41
Cwatz5219's Avatar
Hey crush. Would you recommend this to be done by a prefessional tunning shop or can anyone do it? I'm pretty good with computers and all but not familiar at all with tunning.
Old Jan 1, 2009 | 06:02 PM
  #42
aen's Avatar
aen
Originally Posted by TheFantasticG
Well... Yeah. Is there a better place on this planet than N. Korea?
yea, hawaii.
and unless you have a scanner tthat can tell you fuel trims tunin is useless.
Old Jan 1, 2009 | 06:05 PM
  #43
crush02342002's Avatar
anyone can do it......ima come up with a step by step instructions.....it will be posted in the first page when im able to finish it.......
Old Jan 1, 2009 | 07:53 PM
  #44
ok i posted up some steps to set up your fic but i do suggest that you start with a good base map if you are going to do your own tuning.....other wise have a pro tune you. always start in small increments....it will be frustrating at first cause you really dont see the changes when you start small.
Old Jan 2, 2009 | 12:36 AM
  #45
aen's Avatar
aen
when you edit it it unstickies it, so lemem know when you do
Old Jan 2, 2009 | 12:39 AM
  #46
k ill be done with it for a while unless someone thinks ther should be further explanation
Old Jan 2, 2009 | 12:40 AM
  #47
TCpete's Avatar
this is turning into a sweet thread crush.. props tp you man!!
Old Jan 2, 2009 | 12:41 AM
  #48
thanks.....i try my best
Old Jan 5, 2009 | 06:22 AM
  #49
hotwheelsrs1's Avatar
hey guys do any of u have a link to a good diy or diagram to hardwire the fic to a 2005 tc ecm?, i looked around a bit and didnt really find one
Old Jan 5, 2009 | 06:48 AM
  #50
aen's Avatar
aen
look up the dezod ems diagram they have everythngbyou need ti do this.
Old Jan 5, 2009 | 07:50 AM
  #51
i know its pricey but pnp harness imho is the way to go...
1.its hella easy to install
2.if your having problems and need to disconnect to trouble shoot its easy to unplug
3.i tried to use the bypass harness that came with the fic but it didnt work.
Old Jan 5, 2009 | 01:01 PM
  #52
aen's Avatar
aen
woohoo coherent drunk post.
Old Jan 5, 2009 | 09:14 PM
  #53
i know, id love to get the pnp harness, but the $300 price tag i cant do, and if i wire it all it takes is my time and i have pleanty of that...
or do u guys know where u can buy the connectors to make our own harness maybe?
Old Jan 6, 2009 | 02:46 AM
  #54
now thats a hella idea......you can maybe try boomslang.....give them a call and see if they will part with the connectors for cheap. Try paul @dezod maybe he could direct you to someone. Good luck
Old Jan 6, 2009 | 02:49 AM
  #55
ps for those that wher looking for the type of resister to use for the fic its 1/2watt 2.2kohm........I told someone last week it was 1/4watt......so whoever i told that im sorry for misinforming you....i just seen the package yesterday.
Old Jan 8, 2009 | 07:21 PM
  #56
so i know the toyota ecu will relearn its map and revert back to it over time, do any of u guys know how long it usually takes for that to happen
Old Jan 8, 2009 | 07:30 PM
  #57
bigBOAT's Avatar
saved for later!
Old Jan 8, 2009 | 09:26 PM
  #58
i think there is a slight misconception that the ecu will over write whatever youve done....so far the only time iv seen the computer over ride my changes that iv made is when i used a bs tune that threw the car in limp mode . i think what people really mean to say is that with excessive fuel trims the computer will try its hardest to compensate for it......but if you take away the primary o2 sensor signal and adjust it so that the computer thinks everything is kosher your golden. its not exactly like what ever tune you put on the car the ecu will eventually over ride it, its the fact that not enough attention was payed to the 02 signal. does that make sense?
Old Jan 8, 2009 | 09:59 PM
  #59
ok gotcha and there's no extra harnesses or sensors needed to do that? Just a good quality tune?
Old Jan 8, 2009 | 10:34 PM
  #60
no nothing is needed to keep the tune but i do suggest some other things to consider.
last i heard the auto tranny has a problem with the fic keeping the tb powerd up even after you shut the key off......i cant speak from experiance but thats what iv heard.......but i think what you will need to do if you have an auto is to hook up the fic and check what wire has voltage being sent to the tb....take that wire and either splice in a switch or a relay.
now this i do know you need to splice in 2 resisters into the wireing harness of the fic.......if you dont do this you may get a cam/crank sensor malfunction cel.
one resister will join cam mag- to cam mag+...the other will join crank mag- and crank mag+
the resisters are 1/2 watt 2.2kohm.
you can find the resisters at radio shack, fry's electronics, ect.
