Descendant intake manifold
Old Aug 31, 2010 | 01:21 AM
  #281
m6ar2cel6oTC's Avatar
who is building it? and what parts? turbo?
Old Aug 31, 2010 | 02:51 AM
  #282
Crippie's Avatar
1UP Crew
im building it. itll be my first build, but ive got some automotive experience. (ATI for automotive) and just started at Honda.
sent the block and head to mesa balancing for machine work. bc turbo cams and valve trane - ferrea valves std size street port and polish and 3angle valve job
Cp pistons .5 overbore, bc rods- not the top of the line ones, but the step below. knife edged crank, deleting the balance shafts. went with the cometic head gasket- i have heard the oem one is better, but giving them a try.
currently ive got the greddy turbo 18g, but ive heard and am researching upgrading the internals to a 20g... mostly to be able to keep the IC piping and mani. ive got 750 cc injectors and aem fuel rail but need to upgrade the fuel pump and set up the return style on it. im also workin on either getting a haltech providing i can find a tuner for it, and my budget allows me, or the dezod AP unit. havent decided i also plan on sticking to 93 octane.
wish me luck
Old Aug 31, 2010 | 03:40 AM
  #283
talk to elevationtc for tuning. also GL! 20g>18g&16g
Old Sep 2, 2010 | 10:06 PM
  #284
Crippie's Avatar
1UP Crew
sweet... thanks man
Old Sep 7, 2010 | 10:59 PM
  #285
weezyfbayba's Avatar
does this intake mani take a OEM gasket? was told to call you guy's for the gaskets?
Old Oct 5, 2010 | 07:28 PM
  #286
Rob_DESCENDANT's Avatar
n/a xB running with the DESCENDANT Intake manifold & uni-chip!
http://www.youtube.com/watch?v=sAi3oTH6ITk
Old Oct 5, 2010 | 11:25 PM
  #287
boosted239's Avatar
sounds nice! can you obtain gains on piggyback? im currently getting my head fully built and would love one but i heard piggyback plus new intake manifold wont let you see the effects a standalone will give you?
and crippie the 20g is an AMAZINGLY fun turbo quick spool and at 18psi its hauls some @ss!
Old Oct 6, 2010 | 01:10 AM
  #288
Of course you can. Whether you use the AEM FIC with a PNP harness or a Uni-Chip your gonna make WHP!
If you don't believe me call Jamie at TRD Sparks. They are heavily trusted in the community and that's his xB in the video!
If I'm correct he has the TRD exhaust, TRD Intake & our DESCENDANT Intake manifold...tuned with a UNI-CHIP.
Old Oct 6, 2010 | 01:31 AM
  #289
boosted239's Avatar
what gains are possible with turbo and a piggyback? im not tryin to be to specific just somewhat ballpark im sure thers talk about it in this thread but dont have time to go through all 15 pages.
Old Oct 6, 2010 | 02:00 AM
  #290
there is no actual before and after dyno on the intake manifold. so thats up in the air.
Old Oct 6, 2010 | 02:01 AM
  #291
Depends on what kind of boost numbers you run but from the cars we've been tuning over the past 20 months from our DESCENDANT home in Torrance, CA we seen the following results:
if you run 8-12psi
expect + 8-10WHP
if you run 15-18psi
expect an increase of 20WHP
**you gotta have FUEL SYSTEM...OEM pump & regulator have been replaced at this point.
if you run or want to run 20psi+ OEM manifold doesn't work anymore. Its exploded!
Old Oct 6, 2010 | 02:06 AM
  #292
have you guys experience any blown OEM manifold?
Old Oct 6, 2010 | 02:31 AM
  #293
boosted239's Avatar
well im at 22psi now and havnt had any problems with the oem one but am wanting to step it up to something better
Old Oct 6, 2010 | 02:47 AM
  #294
mason?^^^^^
Old Oct 6, 2010 | 03:17 AM
  #295
game-over's Avatar
There are many tcs over 20 psi that have no problems.
Old Oct 6, 2010 | 04:32 AM
  #296
DMC0585's Avatar
what kind of gains can u expect on a n/a setup?
Old Oct 6, 2010 | 12:19 PM
  #297
Once again there is no actual before and after dyno in either boosted or n/a setups. Plus tuning is a big factor also if you get this.
Old Oct 6, 2010 | 03:29 PM
  #298
Yes, blown/cracked OEM Plastic manifold on 20-22psi race set-up.
Old Oct 6, 2010 | 03:33 PM
  #299
think of it like this...How often are you at 22psi? In the race conditions we test things...which is ON & OFF the boost...for 20 minutes straight, in the Cali dessert heat, they break. A leak is a leak & once its done that its failed.
Old Oct 6, 2010 | 03:38 PM
  #300
Thats not true...thats totally false.
What do you want to see?
We (along with EVERYONE ELSE IN THE WORLD) have stock tC numbers & xB numbers.
We have tC & xB numbers Boosted with the Intake manifold.
We thru Jamie @ TRD Sparks have N/A numbers tuned w/ Uni-Chip.
