Engine Swap and LSD Install!!
Old Feb 8, 2010 | 03:36 AM
  #41
crush02342002's Avatar
hehehe...5am cool with you...j/k
Old Feb 11, 2010 | 02:48 AM
  #42
all4degame's Avatar
any progress carlos?
Old Feb 11, 2010 | 04:13 AM
  #43
bigG2148's Avatar
maybe its just me but u said ur old motor had 67,000 but ur gauge says 13,381?
Old Feb 11, 2010 | 04:24 AM
  #44
Hix's Avatar
Hix
That's the gauge from the new motor. Most of the parts in his engine bay are from the same car.
I believe everything on his car is done or pretty much done.
Old Feb 11, 2010 | 04:42 AM
  #45
yep for the most part its done...he was waiting for his valve cover to dry from paint and to tie up any loose ends. he had to work so this stuff didnt get taken care of.
Old Feb 13, 2010 | 07:44 PM
  #46
Carlanga's Avatar
Alright guys, she's alive!!! I crank her up and it ran great, for about 10sec and I shut her down Reason being that I can't get reverse to go in, I was able to move to every gear when the tranny was out and for some reason it will go to every gear but the reverse position. At first I though it was the shift cables, but I tried by moving the big counter weight on the shifting mechanism and I had the same thing happen. On top of that reverse is in the neutral position, all of the other ones seem to be fine.
My only guess is to try to remove the shift shaft and check if the levers got moved while trying to put it in. I did follow the manual step by step and aligned all three little level paddles up like it showed. Chris was here, he can vouch for that.
P.S. What do you guys think? I would soo love to run the engine, but don't want to keep the clutch down for 10 mins.
Old Feb 13, 2010 | 07:57 PM
  #47
ElevationTC's Avatar
Check the shifter input the 4 bolt section that slides in..
Also did you make sure you bolted down the reverse in the trans.. beilive its 3-4 12 mm bolts!
Old Feb 13, 2010 | 08:07 PM
  #48
Carlanga's Avatar
yep, I did. That's the one that u have to align to the housing and once u put both halves together U tight it down, right? I'm deff doing the shifter input and slide it out and back in and see what it does. I'm affraid it might be the reverse bracket that's inside.
Old Feb 13, 2010 | 08:09 PM
  #49
when u slide the case back together.. there a half circle peice that has a groove it slides into.. and u must remove a 10mm bolt on the other case and reinstall it.
Old Feb 13, 2010 | 08:10 PM
  #50
Carlanga's Avatar
well I guess if I was able to shift every single gear while the tranny was out, it should the the shifter input shaft or shift cables.
Old Feb 13, 2010 | 08:16 PM
  #51
Deff not cables.. But could the shaft.. Or something changed when it spun the gears...
it can be a pain to light up the shift input somethings!
Old Feb 13, 2010 | 08:25 PM
  #52
Carlanga's Avatar
I just hope is not the reverse shift arm bracket that's inside, that somehow I didn't aligned the little hole on it with the reverse shift fork.
Old Feb 13, 2010 | 08:29 PM
  #53
I hope.. I put a case almost back together once.. And then had extra bolts.. scratched my head.. and remember i didint tigheten down the reverse bracket!
Luckly i caught it and fixed it!
Old Feb 13, 2010 | 08:30 PM
  #54
You know... I might make a how to install lsd video..
Would anyone care for such?
Old Feb 13, 2010 | 08:44 PM
  #55
m6ar2cel6oTC's Avatar
Default Re: Engine Swap and LSD Install!!
Sure doesn't mean I'll do it. But good to know how the process is lol. I'll let you put it in my car mike!! And I won't even charge you to install it lmao!!!!
Old Feb 13, 2010 | 08:49 PM
  #56
Ace83's Avatar
Ronin Scion
lsd looks very nice! 850 for a drop in motor is awesome
Old Feb 14, 2010 | 12:30 AM
  #57
so it goes into everygear but revers...isnt there a revers lock out? ima go through the parts list and diagrams again and look
Old Feb 14, 2010 | 12:32 AM
  #58
remove thos four 12mm and pull it out.. make sure all the forks were lowered into postition correctly!
Old Feb 14, 2010 | 12:40 AM
  #59
Carlanga's Avatar
I didn't have the change to play with it, since I had to do a whole tune-up to my wifes car. Dang, those auto tranny oil pan bolts are hard all the way out!!!
Will be driving to California tomorrow afternoon, won't be back till about a week from now. Hope to have some time tomorrow to play with it, if not it's gonna have to wait.
BTW mike, u mentioned that the forks have to be shifted down? I shifted them up before inserting the shaft, maybe that's the problem. We'll see.
Yo Chris, wassup!
Old Feb 14, 2010 | 12:43 AM
  #60
What i mean is.. that shaft they slide on in the trans.. I usually center the selectors before installing them..
Sorry for confusion.. As many trannys ive had apart.. I dont know all the part names lol!
Im guessing when u pull it out.. One of the selector forks was not lined up just forcing it in reverse all the time.. Simple fix! Prob a pita to get in car though! Good luck man!
Glad to see u got a new motor so quickly!
