First time boost questions
Old Jun 15, 2011 | 11:41 PM
  #101
sebbyxtc's Avatar
yes i'm running the FIC and my harness has the resistor mod already. and my gap is .30
Old Jun 15, 2011 | 11:43 PM
  #102
sebbyxtc's Avatar
i reset my ECU like DeAnzaJig told me to and still nothing AFR's are still 17.6-18.0 then to blank. I start the car they start at 14.8 then creep down to the red then go blank and stay blank. The car's wanting to stall out a bit.
Old Jun 15, 2011 | 11:46 PM
  #103
skinnayyy's Avatar
Team Scionara
oh, i use .28 gap. i don't know if that has any difference.
Old Jun 15, 2011 | 11:48 PM
  #104
sebbyxtc's Avatar
it was 0.26 before this happened now theyre 0.30 so idk. I'm gonna drive it to get it tuned in about 2 weeks.
Old Jun 16, 2011 | 05:54 PM
  #105
DeAnzaJig's Avatar
Sorry if i havent been replying on my phone, my cell has been acting up. It's gotta be the 3" MAF pipe, its reading less air by volume causing the ecu to dump less fuel. Thats my theory anyway.
Old Jun 16, 2011 | 08:46 PM
  #106
sebbyxtc's Avatar
Yea dude thats what im thinking....Does anyone know anywhere where they sell 2.5 inch maf sensor pipes for 07-10? i know dezod does but they want $100 for it:O not gonna happen...
Old Jun 16, 2011 | 08:52 PM
  #107
paul_dezod's Avatar
Scionetics
KAD
FYI, it includes 9" of straight aluminum, with a CNC machined flange and hand tig welded onto the pipe. It's more than you may think for the $....
Old Jun 16, 2011 | 08:56 PM
  #108
sebbyxtc's Avatar
Give me a deal? Yo Paul read through the last few pages tell me what you think is going on. You'd be a lot of help.
Old Jun 16, 2011 | 09:12 PM
  #109
paul_dezod's Avatar
Scionetics
KAD
so new questions have come up...
1) i want to have a muffler shop make me a 3 inch exhaust, should i get it from the turbo back or from the s-pipe back? the downpipe and s-pipe are 2.5" and how many resonators? and whats the price range for a turboback or spipe back 3 inch.
Turbo back if you can squeeze the funds and room.
2) how long do i have to get it re-tuned after they install the 3 inch exhaust? My tuner is 2 hours away.
Immediately.
3) my ingh reads 14 on my vacuum, where can i find my leak at?
Could be several places....Should be reading around 20" of HG
4) i want to install the walbro 255 fuel pump, will that affect my tune will i have to get the car re-tuned?
I would recommend it.
So i went to the shop today, since the pipe that wasnt clamping on right was bent after it had blown off, making it read like 11ingh on my boost gauge at idle and it was 12-13 before this happened so obviously i had a leak somewhere, we got one of those 3 inch MAF adapters from pep boys to mount the maf and put 3 inch to 2.5 inch reducer couplers and he put in new spark plugs (ngk) dont know the number but i will get it tomorrow, my plugs before today were ngk coppers and were gapped to 0.26, he gapped the new ones to 0.30 i dont think they were cipper but i might be wrong, anyways he redid the vacuum lines and told me i was getting a bad reading on vacuum because i was getting vacuum from somewhere that wasnt the best so now im getting vacuum from the back of the valve cover valve i think its the pcv valve and it gets t'd off to the vacuum block. Started it up and vacuum went to 20 ingh so normal there now, BUT now my afr's are reading nothing at idle or 17.8-18.0. But now in boost it reads the full 7 psi in full boost and before it was only readimg about 4-5 cuz of the leak, the afr's in boost were 10.7 today after i took it from the shop but read wat i said at idle. Any input? I need help? Should i disconnect the battery to reset the ECU? Wat should i do?
My changing the pipe the MAF housing sits in you are indirectly altering it's readings to provide less air flow at low loads therefore it's fuel calcs are off, hence the lean idle.
The MAF should never be in a transition pipe, at least 4" from BOV, in a bend or near ANYTHING like dryer ducting that can cause turbulence.
Sounds like you need to iron out all of your mechanic/install related items CORRECTLY, THEN invest in a quality tune.
Old Jun 16, 2011 | 09:17 PM
  #110
sebbyxtc's Avatar
So basically what are you saying? What do you think i should do about that? let me upload a pic so you can get a better idea.
Old Jun 16, 2011 | 09:22 PM
  #111
sebbyxtc's Avatar
Before:
After:
Old Jun 16, 2011 | 09:26 PM
  #112
paul_dezod's Avatar
Scionetics
KAD
Before:
After:
FYI, MAF should not be before BOV. ALWAYS after.
Old Jun 16, 2011 | 09:30 PM
  #113
sebbyxtc's Avatar
So what can i do in my case? What do you suggest? What can i do in the meantime of getting it re-tuned? Can it be tuned like this?
Old Jun 17, 2011 | 07:27 AM
  #114
ScionFred's Avatar
Sorry if I'm blunt but unless you can afford to replace your engine and start over you should remove that butt-ugly monstrosity of a turbo setup and go back to stock immediately and then read, ask questions, learn and extensively modify that setup into something that has chance of working properly.
I haven't seen anything that poorly designed and implemented since cburglb34 was allowed to post here.
Old Jun 17, 2011 | 05:47 PM
  #115
sebbyxtc's Avatar
Yea you kinda went overboard there buddy...I appreciate the constructive criticism but you went overboard. You haven't even seen my set up so you have no room to talk, it only started to run like ____ when the 3" Maf pipe got put on, i just ordered a 2.5" pipe from Dezod so i assume it will go back to running good even better now that the vacuum leaks are fixed. I made 273whp 269 ft/lbs on 7 psi on this "butt-ugly" set up so you have no room to talk, before you come in flaming people just stop and think -________-
on another note, you think the turbulence and running like ____ will be fixed since im going back to 2.5" MAF pipe?
Old Jun 17, 2011 | 07:00 PM
  #116
ScionFred's Avatar
It didn't sound so bad last night when I wrote it but then I was kinda drunk at the time... sorry dude. My bad.
What can be seen in the photos you posted is pretty messed up though. As Paul said, the BOV should be before the MAF. The MAF tube should be 2.5" ID and your PCV system should be connected or at least put a filter on there. I suppose what I meant to say is that there are some fundamental issues that need to be addressed before tuning it.
The 2.5" MAF pipe should help a lot but the MAF should be where the BOV is now and the BOV should be as far in front of the MAF as possible. The PCV connection should also be before and as far from the MAF as possible. All boost pipes should be bead rolled or at least have a bead welded on so they don't keep blowing apart. If you do it right the first time, you won't have to keep fixing things.
Good luck.
Old Jun 17, 2011 | 09:28 PM
  #117
DeAnzaJig's Avatar
Sebby, you have the pipe on backwards. ive done this before with the ZPI kit. switch it around, and it should fit snugly and be in the proper order. i can tell because the crank case vent is on the oppisite side, meaning its backwards. flip it around with the old MAF pipe, and see what happeneds
Old Jun 17, 2011 | 09:30 PM
  #118
DeAnzaJig's Avatar
Cause your intake pipe is completely backwards in order. Now you have:
1 - throttle body
2 - crankcase vent
3 - BOV
4 - MAF
It should be
1 - Throttle body
2 - MAF
3 - BOV
4 - Crankcase Vent
Old Jun 17, 2011 | 09:51 PM
  #119
DeAnzaJig's Avatar
see
Old Jun 17, 2011 | 09:59 PM
  #120
skinnayyy's Avatar
Team Scionara
holy cow! good catch on that one! i'm surprised all of us missed that
