Help with Scion Tc S/C low rpm problem
Old Nov 13, 2007 | 01:39 AM
Vielo18's Avatar
Default Help with Scion Tc S/C low rpm problem
Hey I'm new here and I've just supercharged my automatic TC. THe problem I have is when I start the car for the first time in the day. Its starts really lazy and the RPM is about 500. I notice the throttle response a little low. It has already turned off once when I was heating the engine in the morning. Some people tell me that the engine is running a little low on fuel. Has anyone has the same problem? Can anyone help me? Thanks.
Old Nov 13, 2007 | 01:44 AM
unxpectederror's Avatar
are you sure it was reflashed?
Old Nov 13, 2007 | 05:57 AM
Vielo18's Avatar
yes im sure it was reflashed. you can notice the diference rpm.
Old Nov 13, 2007 | 06:12 AM
gqdabien's Avatar
I had that same problem. Cold mornings it'll feel like the engine is struggling to keep from stalling. However I haven't had it die on me before. I had this problem since July.
Old Nov 13, 2007 | 06:14 AM
Vielo18's Avatar
so you still have the same problem?
Old Nov 13, 2007 | 06:17 PM
gqdabien's Avatar
delete
Old Nov 13, 2007 | 06:19 PM
gqdabien's Avatar
Yes i mean i "have" that problem. Lately if it starts, it'll start off lazy then it'll idle higher around 1 - 1.5k, if it dies it'll die quickly. Mine usually takes 2 cranks to start in cold mornings outside. I created a similar thread and the response I got was that it is a common problem in Xb's.
Old Nov 13, 2007 | 09:30 PM
Vielo18's Avatar
people tell me to check the fuel-air ratio because TC's run a little low on fuel because of the supercharger. I dont know how true that is. The other thing I'm thinking about is reflashing the computer again. I'm hopping someone here has solve the same problem.
Old Nov 13, 2007 | 09:40 PM
aen's Avatar
aen
sparkplugs?
check all connections, might be a vac issue.
Old Nov 13, 2007 | 09:44 PM
BrownDogg's Avatar
Its not the connections... I had the same problem when I had my automatic tC supercharged. I checked everything. I sold it before I solved the problem...
My final conclusions led that it was the oil return line to the S/C. After it sitting for so long, the oil would drain down the line and once cranked it pumped the oil again up. then shut it off then start on the second time and it starts up fine.
Old Nov 13, 2007 | 10:39 PM
Vielo18's Avatar
I will check all the option to see if the problem stops. Thanks
cid_mcdp
Jan 5, 2015 02:45 PM
fluxingnation
Dec 26, 2014 04:28 PM
rcflyer15
Dec 5, 2014 05:15 PM
eric_m
79
Mar 17, 2013 12:21 AM
Risen_Son_Racing
Oct 12, 2003 01:21 AM
