IAC Valve?
Old Aug 29, 2010 | 11:18 PM
twinscrollinxrs's Avatar
Default IAC Valve?
Where is the IAC Valve located? Is it somewhere on the intake mani, or is it really on the throttle body? I'm getting rpm surges
Old Aug 30, 2010 | 01:46 AM
Tc4Eva's Avatar
Team ScionTific
From what I know, I dont think we have one. I believe its all computer controlled. If your boosted, Im gonna go with it being the tune.
Old Aug 30, 2010 | 02:30 AM
OuterHeaven's Avatar
We do not have a IAC valve. The ecu controls idle (high or low), throttle, cruise control, rev limit (07+ only), and I believe the speed limiter for 07+ all with the electronic throttle body. This must be tune related or a small vacuum leak.
Old Aug 30, 2010 | 02:53 AM
m6ar2cel6oTC's Avatar
search the forum there is dozens of thread talking about rpms surges and rpm bouncing.
Old Aug 30, 2010 | 02:55 AM
gingles's Avatar
bahahahaha....yea the IAC valve is with our flux capacitors under the rear differential.
Old Aug 30, 2010 | 04:31 AM
deathbyc4's Avatar
its ECU controlled, you have to go standalone (T1 development iac control with AEM EMS) to adjust it.
Old Aug 30, 2010 | 06:55 AM
Ace83's Avatar
Ronin Scion
yeah our idle air control is on our ecu, idle control by small opening in our throttle to allow flow on idle.. there's a lot of factors that causes surging, different ems/standalone could have different fixes.. what management you are using?
Old Aug 30, 2010 | 10:20 AM
I'm using the AEM FIC, but i found the problem, it was a small vac leak from the one of the RC injectors, the rubber grommet that sits on the mani/block had a rip in it causing the injector to not sit right, I sprayed the engine with brake clean
and when I got by the injector the motor cut off, so I checked it and I replaced it and now its all cherry. I thought it was a vacuum leak after I noticed my boost gauge was at only 10 on the vac side on idle, so thanks guys, problem fixed.
_______
Old Aug 30, 2010 | 02:02 PM
Spr4yedTc's Avatar
happy birthday and happy boosting
Old Aug 30, 2010 | 04:51 PM
oh, thanks man
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
brett561tc
Sep 15, 2015 06:33 AM
6885BLM8435
Aug 19, 2015 03:08 PM
