Its ALIVE!
Old May 16, 2009 | 02:02 AM
  #61
RusWolf's Avatar
stock sleeves. I cant afford sleeved block at the moment . Plis stock sleeves should be good up to 500WHP.. and i'm looking for 400WHP.
Old May 16, 2009 | 03:53 AM
  #62
crush02342002's Avatar
id like someday to see 500...or atleast know what it feels like...lmao
Old May 16, 2009 | 03:55 AM
  #63
CarbonXe's Avatar
Go test drive a Vette
Old May 16, 2009 | 04:06 AM
  #64
they wont let me...lmao
Old May 16, 2009 | 04:12 AM
  #65
RusWolf's Avatar
hey guys i got few questions i asked on previous page..
my 550 cc injectors are good for what power ?
also with new short block, which stud should i change to ARP ?
i know headstuds as advised by my shop, but what else ?
also to support around 400WHP will standard dezod FMIC do it ?
or should i just stop at 350-370
Old May 16, 2009 | 04:15 AM
  #66
idk...i would think that either stick with 550cc but run higher fuel pressure (return system w/ walbro fuel pump and fpr)
or upgrade to 750cc injectors...i would think that would work but ther is a specific formula for finding out...
Old May 16, 2009 | 04:21 AM
  #67
RusWolf's Avatar
return system with walbro at the moment not worth it for me because i'm deploying to Iraq in september and this would be too much stuff to put in the car and not play with it , lol
i'm thinking about dewtsch 700cc injectors.
or i'm thinking to just install what i'm getting and tune it for 350 on high since block will hold it now and call it quits 'till i come back.
Chris do you know about studs and stuff ? what to change ? headstuds and ....? or is it needed other then what i listed ?
Old May 16, 2009 | 04:33 AM
  #68
well is erl doing the head too or not...i dont think they do but curious if you could have sweet talked them into doin the head too. id call and ask erl about what they suggest. most likely they will tell you to get new head bolts...idk what the tq specs are or what the part number is...erl could tell ya though. I think arp makes head bolts for our cars.
Old May 16, 2009 | 04:57 AM
  #69
RusWolf's Avatar
i spoke to ERL and Sean was looking in the catalog and couldnt find the headbolts by ARP. By i found them on Dezod website.
I'm just thinking that i will definately get heaadbolts and cometic headgasket.
Just dont know what else or what other bolts need to be changed.
Actually ERL they dont build heads, nor am i interested in it at this time. Next year i will get Dezod built head and BC stage cams for forced induction.
Old May 16, 2009 | 05:33 AM
  #70
Mrsanchez925's Avatar
did you ever figure out how your engine blew??
Old May 16, 2009 | 02:03 PM
  #71
Ace83's Avatar
Ronin Scion
^^ its gonna be hard to know, simple answer is he detonated.. i wouldnt go back and figure out though but just move on
Old May 16, 2009 | 03:56 PM
  #72
RusWolf's Avatar
yeah there is no way to find out...
my guess is that rod ws weakened before i got properly tuned as i damaged it. and it was a matter of time 'till it would happen.
Old May 16, 2009 | 04:05 PM
  #73
my06tc's Avatar
WRX here
Old May 16, 2009 | 04:23 PM
  #74
Ace83's Avatar
Ronin Scion
It takes some good force or detonation throw a rod through the block so my guess is that the car detonated... a weak rod without detonation most like will get bent first and some knocking/grinding or weird engine noise will be noticed before the motor completely goes so my guess is that a knock have trigger that..just my opinion though
Old May 16, 2009 | 04:35 PM
  #75
RusWolf's Avatar
Ace what kinbd of clutch are you selling ? stock ?
i wonder is 91 octane has smthng to do with detonating.. i was tuned for 93
Old May 16, 2009 | 09:21 PM
  #76
Ace83's Avatar
Ronin Scion
yeah just the stock clutch... 300ish hp i recommend some stage 4. 91 could be contribute too but cant blame it totally on that, it could be a lil bit of everything plus combination of badluck
Old May 16, 2009 | 09:53 PM
  #77
RusWolf's Avatar
will Stage 4 hold 400 ?
How is drivability on CC Stage 4 with 6 puck plate ?
Old May 16, 2009 | 10:06 PM
  #78
RusWolf's Avatar
Also i came up with new plan for getting the car to WA state. Instead of driving i'm probably going to transport it. yes i know its going to cost me money, BUT i dont wanna break down in the middle of nowhere.
So i will probably put the car on the truck right after its built and checked for everything. the once i get it in WA i'll break the engine in and then tune it.
Old May 17, 2009 | 01:13 AM
  #79
understandable...one bitten twice as shy
Old May 17, 2009 | 01:18 AM
  #80
RusWolf's Avatar
yeha man and plus to it i'm saving the car from additional 2000 miles.
I spoke to my shop today and they said because my engine will be out its going to be easy and wont cost much to install the clutch.
Also thinking whil doing the clutch if i have the money i'll get flywheel as well.
i assume 2-3 hours of work with engine being out already ?
