Supercharged 1320ft results. 4/28
Originally Posted by desertheat
I bought the trd led shuft light and programmed her perfect to flash at 6350, by the time I react I am right at cut off.
I can program my HKS turbo timer type-1 to beep and display red in color when I hit a selected rpm. So, what is the redline for these cars? 6500?
Originally Posted by kcautotc
just a question, how did you test the times for your cars and not know the redline? or am i misunderstanding your post?
Are you talking about my post? I know where the redline is, I just wanted to know the actually "physical" number. I can just look it up I reckon...
Hooked up a boost guage. The charger is putting all 9lbs. ok as of 7:40 pm est. I did a complete look over. I found oil in the compressor housing, which is coming from the hose from the valve cover. I also did a compression check. Found all 4 cyls are 125. Seems very low. anyone know what it suppose to be? Thanks
125..??? uh oh.... that sounds really low. Also there will be SOME oil in the compressor housing but not tons. Try starting it and pulling your dip stick out 1/4 of the way and see of there is allot of blow by or gasses coming from the dip stick.
Originally Posted by SuperWTC
Originally Posted by TimmyT
14.9.. You do realize edmunds got a 15.1 on a stock tC with stock supercharger(Who admittedly did NOT know how to drive the car. In thier article they say It took over a dozen runs for them to get a 15.1)
Sorry guy. but sounds to me like you just can't drive your car.
You can say all you want, but your times don't lie.
RIP 2azfe.
Scott,
http://www.leesvilleauto.com/ in Rahway NJ has 2 tC motors for $750, call em and ****** one up.
If not
http://www.als-auto.com/ in Trevose PA has a ton of 2azfe's for $750 as well.
Your fairly close to either location.
Scott,
If not
Did you have the trd reflash..?
I did but it was like 5 months ago. Think it was around 190 hot. Have lots of blow by out the dip stick tube..? Also most likley if you cracked all your ring lands on all 4 cylinders then the dealer did NOT do the trd reflash. Keep us informed, sorry about the crappy situation.
rain7905643
Jun 13, 2018 05:29 AM
