Valve slap?
Old Jan 25, 2013 | 04:31 PM
Thanatos's Avatar
Default Valve slap?
OK when hitting full boost and changing gears the person who helped do my install claims he hears valve slap. Its like a small clank after changing gears. OK info on the kit its a zpi stage zero with the wastegate dump left open. He says that's the problem. Aside from a stripped nut causing oil to leak from the return the car ran, idled, sounded smooth as could be. Is this "valve slap" a real issue with our cars? The guy that helped is going to school to be a mechanic but he mostly works on VWs.
Old Jan 25, 2013 | 04:38 PM
Thanatos's Avatar
I was thinking maybe the sound was the spring slamming shut after boost is released
Old Jan 25, 2013 | 08:58 PM
tom0613's Avatar
put an oil pressure gauge and see what that is. most of the time you will valve train noise when the car is cold then quiets down but if your hearing it from in side the car you might have a problem. usually what cause valve train noise is valve lash which is easy to check. but from my under standing from owning motorcycles that have shims as well is that when valve train starts to quit down is when u need to worry and gauge the cam caps, bucket shims, etc. reason they get quit is because the valve seat gets worn down and causes a tighter clearance between the cams and the shims.
Old Jan 26, 2013 | 12:33 AM
rhythmnsmoke's Avatar
Music City Scions
Yea and the wastegate being open is perfectly fine. I run two wastegates and they both are DTA.
Old Jan 26, 2013 | 12:59 AM
tom0613's Avatar
I wrote the wrong info there I should of read more lol. I saw valve slap and thought you were talking about the cylinder head.
Old Jan 26, 2013 | 01:02 AM
Music City Scions
Oh, he wasn't referring to the head? I thought so too.
Old Jan 26, 2013 | 02:19 AM
tom0613's Avatar
reading #2 I think the talking about the waste-gate making a slap noise.
Old Jan 26, 2013 | 09:59 PM
Thanatos's Avatar
Honestly I think he's just paranoid I don't really head the sound. Basically he's saying the pressure being released so fast is making the valves slap around. I'm trying to figure out if that happens with boosted TCS and if the waste gate closing makes a sound. I've had factory boosted cars but this is the first one I've boosted myself.
Old Jan 28, 2013 | 06:31 PM
Thanatos's Avatar
So I guess waste gate closing doesn't make a sound? Or maybe i worded my post wrong and no one knows what im talking about lol. Well getting thread fixed and waste gate dump welded into downpipe and hope for the best.
Old Jan 29, 2013 | 01:25 PM
Music City Scions
What brand wastegate? I have never heard mine make any sort of sound when closing. I have a two of them. And both of them dump to the atmosphere.
Old Jan 29, 2013 | 08:37 PM
tom0613's Avatar
me to but never heard the slapping sound he is talking about
Old Jan 29, 2013 | 11:27 PM
sofTCheese's Avatar
i have a ZPI stage 1 and had something similar to this and and my car ran funny when it started happening. i was running a tial wastgate so i went to see what it was and i took off the wastegate and the valve of the wastgate broke off the stem so when i rolled into boost some how it didn't spike i dont know how but it just ran like crap. so you might want to take the waste gate off and have a look just in case.
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
Rob54Monty
Jan 20, 2016 01:41 PM
6885BLM8435
Aug 19, 2015 03:08 PM
