2007 Scion tC - CarPC DONE!
Originally Posted by Runawayrogue
Here's a question for you... How easy was the screen install into the dash? and is it reversable?
I have built many carPCs for people before, but never installed one myself and am really wanting to do it myself finally... I just don't want to risk screwing up my center console...
you have an awesome set up there.. i've been doin mad research and i wanna try it when i get back home. props, take it easy.
oh, are you gonna post pictures or instructions on how you installed it? it would be cool.
-1-
-1-
Originally Posted by mike6789k
Alright due to popular demand, here is what I got...
Lilliput 7" Touchscreen
Bondo, spraypaint, floral foam, etc for fabrication
Mini ps/2 keyboard, ps/2 extension
vga extension
usb extension
amp, speaker wires, power wires, inline battery wire fuse, battery terminal, etc...
wifi adapter
bluetooth adapter
microphone
gps adapter (bu-353)
power distro block
40gb 2.5" hdd
low profile 256mb ram (this is plenty, trust me, boot up time is much faster with less ram too)
M10000 mobo
m2-atx power supply (works great!)
voom pc ampie computer case
rounded ide cable
serial extension
obd-ii from digimoto.com
and im sure alot of other things im forgetting right now... but you get the idea
vga extension
usb extension
wifi adapter
bluetooth adapter
microphone
power distro block
40gb 2.5" hdd
M10000 mobo
rounded ide cable
serial extension
azn - i have a 2 channel sony xplod amp, lol...
calvin - you can use a hack to modify your cell phone software to allow it to give internet access via bluetooth modem without paying anything!!!
so i did more reading on mp3car.. and i came up with a list and made a diagram. can you please check it out sometime and review it? thanks.
https://www.scionlife.com/forums/vie....php?p=2174590
ok, well, you have to be careful running your monitor off of the ignition cable as someone suggested. if your monitor has a power filter, then you can and SHOULD use the ignition wire... HOWEVER, if there is no inline filter on the wire, you will NEED to either build a filter or power it from the 12v rail from the psu.
this is because the ign wire is not a stable 12v and fluctuates alot around 13.8v... not good for your CCFL's, this will cause your monitor to break prematurely (although it will be brighter for a while lol)
gotcha... the specs on the monitor says the operating voltage is 11-16V, would it still be cool to run it off ignition? i can't find anything about an inline filter so i figure it doesn't have one.. http://www.mini-box.com/VM7000-7-touchscreen thanks for the super quick response.
Originally Posted by aznlaoboi07
i'm not back home yet, i haven't purchased anything.
plus, the lilliput screen is easy to fit behind the door cover...
well... not EASY, but you can do it... some screens are impossible to fit
NonStopTuning
Jan 20, 2015 05:20 AM
Beesh
Jan 9, 2015 06:30 PM
minter66
Dec 15, 2014 01:45 PM
foxSCION
13
Dec 3, 2003 05:40 AM
