Avic D3 Installed
Old May 19, 2007 | 07:19 AM
  #101
Phanon_TC's Avatar
i have yet to try videos on a playlist method as I don't play videos that often lately. I do know that once I load my video playlist, I can use the D3 or my steering wheel controls to go forward/back a video. Guess i'll give it a shoot since its the weekend and see how it goes. As for the divx movies, it works fine and I converted 100+ mpeg music videos into divx. Xvid does work but you must change the video header. Basically tricking the avic to think xvid movies are divx format. On my long drive to AL, I burnt many xvid movies to dvd to watch. It would randomly stop/skip/desych at some point of the movie. Didn't have problems with short xvid tv episodes though. Not sure why though but ever since then have resorted back to using my IPod for video usage.
Old May 19, 2007 | 09:21 AM
  #102
O5_TRD_tC's Avatar
How do u get videos off ur ipod to display on the D3 screen?
I'll select a video but all I get is teh audio from the car speakers but the video is still displaying on the ipod.
Old May 19, 2007 | 05:35 PM
  #103
Phanon_TC's Avatar
videos > video settings > tv out > on
videos > video settings > tv signal > ntsc
Old May 19, 2007 | 05:54 PM
  #104
O5_TRD_tC's Avatar
YAY! thanks it worked!
Old May 28, 2007 | 08:33 AM
  #105
punkemoskaHXC's Avatar
So, from what you said earlier, the little aux-looking plug on the face of the navi screen is just for iPods only?
Old May 28, 2007 | 09:12 AM
  #106
ADRdesignCo's Avatar
i think its for anything that can handle mini video inputs. though mostly ipods, if you get the connector for it its a mini plug to 3 RCAs with 3 rings around the miniplug instead of normal audio with 2. from those 3 RCAs you can plug in anything youd want with RCA connectors on it
Old Jun 6, 2007 | 07:41 PM
  #107
Red_tC's Avatar
I am installing the d3 this weekend and looking for opinions. Is it better to set the unit back as shown in the install or dremel the inside of the cover?
Old Jun 6, 2007 | 08:10 PM
  #108
ScionJim23's Avatar
set it back by redrilling mounting holes. Looks better IMO
Old Jun 6, 2007 | 08:31 PM
  #109
i say set it back. too bad i already dremeled my door.
Old Jun 6, 2007 | 08:56 PM
  #110
satoman44's Avatar
im just curious, why do you wish you set it back?
Old Jun 6, 2007 | 10:55 PM
  #111
O5_TRD_tC's Avatar
i thought u have to set it back and dremel a hole?
Old Jun 7, 2007 | 02:44 AM
  #112
Phanon_TC's Avatar
set it back? becuz the **** on the avic d3 blocks the door from shutting using the stock holes on the bracket
drill holes and u will be fine.. cleaner and easier to do than dremeling the door away.
least when u drill holes on bracket and mess up.. it'll be hidden.. not so much with the door
Old Jun 7, 2007 | 02:48 AM
  #113
Red_tC's Avatar
Thanks, drilled it is.
Old Jun 7, 2007 | 05:46 AM
  #114
charding81's Avatar
Can you explain how to change the video header? and you say tv shows work fine but movies flake out? are they watchable or does it go out of synch permenantly?
Old Jun 7, 2007 | 06:03 AM
  #115
magnetic's Avatar
Someone convince me not to use my credit card to buy a D3. Hurry before I do it!
Old Jun 7, 2007 | 07:48 AM
  #116
itstang's Avatar
so wat kind of ipod adapter did u buy is the one thats 30 dollars and it still shows video in ur headunite because i hav an alpine iva w205 and got the 30 ipod cable and the video doesnt work in teh heaunit
Old Jun 7, 2007 | 07:56 AM
  #117
Phanon_TC's Avatar
https://www.scionlife.com/forums/vie...475768#2475768
and yes the xvid file randomly poops out and have to restart it. i gave up on it and just converted everything to my ipod. now i have 10 gigs of music videos and 10 gigs of tv shows/movies on my ipod available
Reading on the Alpine ivaw205 from crutchfield website
"The IVA-W205 will not navigate or display video files from video capable iPods."
even with the ipod cable. so pretty much either use a one of those cables to convert to regular RCA or go a little further and buy a home dock so u can have a remote controller
Old Jun 7, 2007 | 08:51 AM
  #118
anyone else getting like a noise when they pass 7 for their volume? kinda like a HISS?
Old Jul 3, 2007 | 01:33 AM
  #119
Joeydubb's Avatar
So just to make sure.....to do the bypass you need to ground the green "parking brake" wire and the yellow/black "mute" wire and thats all?
Old Jul 3, 2007 | 02:50 AM
  #120
magnetic's Avatar
^^ also, you need to move the mute wire from its factory position in the plug to the one space above it.
