Eclipse AVN2454 installed on 06 tC ***pix update***
can the eclipse nav unit be used on the fly? or do you have to completely stop like with the pioneer? i know you can probably overide it either way but wondering if you could do it without the ghetto rig
to use your steering wheel controls he had to use a device called "PAC". they are used on gm vehicles and from what i understand they made one for scion/toyota. not too long ago. heres the link below:
http://www.sjgreatdeals.com/mon125367.html
if you have no need for navigation buy a kenwood ddx 8017, 7015, 7017. thats what i did for 600 bucks too. i got mine off ebay too.
here the pic of the device need & part number + name MON125367 MONSTER CAR MPC FX IM-TOY1 Interface Module For 1998-2004 Toyota
Originally Posted by 2006XB
Originally Posted by zyzyx6969
BTW, Eclipse (Fujitsu Ten) is a high end namebrand
hahahahaha, I'll take some pix later, we'll see what is BS !!! :D
Hey zy, check your invoice or call the place up and ask them if they used adapters to make the steering wheel volume controls work with the Eclipse HU. If you believe you're right and everyone else is wrong, Im sure you won't have a problem asking them.
BTW, Eclipse (Fujitsu Ten) is a high end namebrand, and always better than Pioneer, no matter what you say. Period. Ask people around here, make a poll or sth, Eclipse vs. Pioneer, heheheh!
Alrite...
So the steering wheel controls work for both HU's, you just need to buy the adapter?
For the D1, if I want to watch DVD's on the fly, I have to give up the rear camera?
How does overrideing the hand brake work?
Originally Posted by ricexizxgood
Alrite...
$100 for labor and 2 more years warranty . Period. This is funny, why would they give me FREE part without charge ?
I also pulled the h/u out to run the RCAs (& stuff) AND to relocate the Nav antenna, the only thing I saw (different from the diagram) is 1 extra wire. THAT'S IT !!! Period.
BTW, if you have an aftermarket h/u on your '06 and you can't use the steering wheel audio control, hahahaha, too bad for you.
seriously!!!
hmmm i have to check with a couple of shops locally to see if its pre wired into the stock harness which i bet it is. is there any way you could take a pic of the install in the rear. especially the harness section because im really interested knowing what the difference is in the wiring.
thanks for the info.
Yes, I agreed. $100 too much for PLUG & PLAY (& drilling holes) installation, but I need the warranty (hahahha, of course for a reason).
The speed sense wire is NOT an extra wire, it's an optional, either you tap it to the speed pulse wire or NOT, the Nav still works, but once you lose GPS signal, it'll be messed up.
So, the speed sense wire is NOT considered EXTRA here.
I'll take some pix later !!!
