My Electronic components is messed up..
aha! the yellow wire is for constant power, like when the dome light than can stay on all the time, red is for a switched 12volts power that stays on when the engine is on like the cig lighter, if u crossed them then when engine is off, the yellow wire is giving power to everything... correct me if im wrong but that the way i remembered it.. So did you find the out where is the prob?
ahh.... so i should just cap off the yellow wire then eh? ill do it on monday cuz my friend's garage isnt open n i dont have the tools in my garage.. ill go see to that n tell ya how it goes..
The yellow wire has 12V+ on it all the time. When you tied that to the red wire (switched 12+V), you've bypassed the key/switch. This effectively puts 12V everywhere - making all your accessories work - despite key position.
By properly wiring them (not tie the red/yellow together), your accessories will work when the key is on, and stop when the key is in the off position/removed. Whomever told you to do that - ignore any further advice from them.
The Yellow is constant 12V
The Red is switched 12V by the key position
DO NOT TIE THOSE TOGETHER!
yea i figured, ur last post just confused me, theres no yellow wire in the harness so i'll just go ahead n cap it off, i also got an ipod adapter so i will mind as well hook that up..
You're not using a plug-and-play harness like this are you...
http://bestkits.com/ViewImage.aspx?img=i/BHA1761.jpg
yes exactly, theres no yellow so im thinkin bout just cappin it off..
Strange, what brand is your deck?
Most use standard colors, only exception I can think of is really really old Pioneer. For those old ones, the thicker orange with a fuse is the 12v constant if I remember right..
ok now dont go flammin on me but with the money i can afford was a Dual XDVD8265 and im using the exact same harness as the link above, note that i can still get that instruction bag for that harness..
Side note.. an asian female friend said that hummers look better than a scion tc (i hate hummers with a passion useless pieces of S**T... fugly as*s cars)
Note that is an authentic japanese Razo black carbon fiber wrapped shift ****
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Armystrong
Aug 31, 2015 08:19 PM
