Official Interior Dash Thread...
Old Jun 3, 2011 | 06:26 PM
  #1521
Irishguy0224's Avatar
As far as i know a lot of new head units make it hard to continue to use the door which sucks. When i get a new double din, i don't need the hood rats checking out my ****
and it is Duplicolor Toyota Blue (i believe) it does have some flake in there. Turned out great imho
Old Jun 4, 2011 | 02:36 PM
  #1522
thegame7a's Avatar
Originally Posted by jazfromhouston
^^ That Blue Metal Speks?
Side Note : Anyone have an easy fix as to closing the door with an aftermarket HU with a little ****? I figure I could dremel the door, but I wanted to keep it as a last resort.
Is your radio all the way installed in the last holes of your kit? Have you took the door apart before? Cause i removed the plastic piece thats behind the door, it pops right off with a little force. My door opens and closes with no problems at all and i have an Alpine double din.
Old Jun 4, 2011 | 05:48 PM
  #1523
Dam262a's Avatar
u have to make new holes in your stock bracket, to make it a bit more back.
Old Jun 7, 2011 | 03:16 PM
  #1524
Who are you talking to mr i love caps?
Old Jun 7, 2011 | 07:48 PM
  #1525
Dam262a's Avatar
lol who are u talking too?
Old Jun 7, 2011 | 08:38 PM
  #1526
Ah, the comment got deleted.
Old Jun 8, 2011 | 08:09 AM
  #1527
JBell91's Avatar
In the process
Duplicolor Storm Gray Metallic on my FM
Attached Thumbnails Official Interior Dash Thread...-258581_10150270346203035_760153034_9006941_2589428_o.jpg
Old Jun 8, 2011 | 08:25 AM
  #1528
Dam262a's Avatar
it was probably spam, i usually ignore those
Old Jun 8, 2011 | 01:19 PM
  #1529
jazfromhouston's Avatar
It is. I installed it myself. My **** isn't as big as other ***** I've seen in here. (Sounds perverted, huh) You're talking about the black plastic on the back of the radio door? I can easily drill holes, but this would be easier. I have two extra waterfalls. Thanks in advance.
Old Jun 8, 2011 | 08:20 PM
  #1530
JBell91's Avatar
Was painting my bottom waterfall last night and got a run in the clear coat, so I wet sanded it down a couple times, and apparently missed a spot....unknowingly and recleared it. Also noticed that I took some paint off on the corner (its now black)....question is can I re-wet sand and paint again (over the clear coat). Its only one small spot so I dont want to wet sand the whole side just to respray and clear it again. Could I get by just doing the small spot.
What would you guys recommend?
Old Jun 10, 2011 | 07:30 PM
  #1531
I would assume you have to re-do the whole side. Unless you can manage to ONLY paint that one area that you re-sand.
Old Jun 12, 2011 | 09:31 AM
  #1532
RaidenKnight's Avatar
Originally Posted by Wavechaser
Finally done. Flat black all the way around.
thinking of doing the same color but wanted to know how you painted around all of the buttons and the screen.
Old Jun 12, 2011 | 01:52 PM
  #1533
thegame7a's Avatar
HVAC controls is one unit, it comes off if you want to paint your waterfall. Just pull the center **** off and then behind the waterfall if i remember correctly i think theirs clips or 4 to 6 screws you just take off then you can remove it. From there you can paint away without messing up the HVAC.
Old Jun 12, 2011 | 02:13 PM
  #1534
thank you. i actually went out to my car and figured it out right after i posted the question. thank you for your answer though.
Old Jun 20, 2011 | 01:39 PM
  #1535
TRD-Chris's Avatar
wow, a lot of these looks amazing! Sad that I have no experience in painting or I'd paint mine lol
Old Jul 13, 2011 | 09:05 PM
  #1536
JTAC's Avatar
I have no experience either. Look what I can do!
Old Jul 15, 2011 | 06:27 AM
  #1537
Dam262a's Avatar
^^^ LIES!
Old Sep 7, 2011 | 03:18 PM
  #1538
michaelh90's Avatar
Old Sep 7, 2011 | 03:19 PM
  #1539
Dam262a's Avatar
^^ i can't even see your dash
Old Sep 7, 2011 | 03:37 PM
  #1540
michaelh90's Avatar
=0
