TC problems : I need a bit of help
I have an 07 TC, barely has 99k on the motor , the other day I took off early morning to work , drove about two blocks and the car sputtered and shut off , haven't been able to turn it on all week , battery is at 100%, fuel100%, oil 100%, coolant 100%, battery stays charged , alternator is at 100%, my only idea would be a bad fuel filter , any ideas
Is it throwing any codes?
Are you running any aftermarket intake? oiled air filter?
Check the MAF
also could be the crank position sensor.
Check your battery terminals while your at it. it may look fine but if you have a bad ground, things will act funky.
Check the MAF
PushyTop
27
05-21-2004 10:19 PM
