Battery Relocation?
Because it's not worth the trouble.
I run a Magnapower AGM battery that weighs about 15lbs and cost about $80.
It fits under the stock hold down, but the battery is on its side.
Simple fix, lost about 10-15 lbs, without the added weight and complexity of relocation.
Yo what model is that? I want a lighter battery, but I wouldnt want to pay triple for a braile batt. Looking for something that will still work decently with my audio setup which is two JBL power amps (1 for 2 subs, 1 for 2 pairs of comp's). Looking for something with a decent CCA rating to turn over the batt in the winter season too.
i know its not part of the suspension, im just looking to get some crap out of the bay and i know relocating the battery to the trunk will help with weight distribution and therefore handling, however small it may be. im stripping the tc down for a track car so every little bit helps.
There has to be something on Youtube somewhere or something......just as long as positive battery cable going back up to front of car is in a place where it won't get cut, frayed, etc, go for it. There might be a kit at Summit Racing for cheap.
I do race. I bought my Magnapower at Meijer. I think most auto parts stores carry them. Mine has 330CCA for a driven racecar. You can go even smaller for a trailer queen. Don't forget your relocation kit includes at least one very long cable, and the mounting box, and the weight benefits are smaller. Look at DG Spec's tC. See what he does.
What do you weigh? I see racers all the time spending money on weight reduction on the car, when they didn't look in the
Mirror.
Mirror.
I almost forgot. Measure your hold down, and get the Magnapower that has that dimension for the widest dimension. Lay the battery down, and mount it. I did modify my cable ends because I bought a motorcycle battery. If you drive your car, a 10 pound battery isn't recommended.
drgonzo92
14
04-24-2019 07:27 PM
knuckleheadjcz
12-24-2015 09:07 AM
