brake pad change - no how-to? why?
Old Nov 27, 2006 | 04:31 PM
  #41
JZA70's Avatar
it's amazing what a little searching can get you. this was posted over a year ago:
https://www.scionlife.com/forums/viewtopic.php?t=86011
Old Nov 28, 2006 | 05:25 AM
  #42
vaccaro's Avatar
Originally Posted by jwaggz82
Originally Posted by vaccaro
i was wondering when you are look at the caliper all i see is a bolt behind the caliper. so you take that off right. then what.. what do you do from there. are u supposed to pull out that metal strip that looks like it holds the pads in?
there are 2 bolts that hold the caliper on. Take both off. Then take the caliper off and put it ontop of the rotor ...dont have it hanging there by the line. Next the pads are now right infront of you since the caliper is off. Take both pads off and put them back on 100% the same way you took them off ...but with the new pads. You are going to use those metal holder pieces that the OEM pads came with.
Next you are going to have to take a c-clamp and depress that piston so the caliper can fit back ontop of the pads (since you now have a lot more padding ....the piston is pushed too far out and needs to go back in more).
so should i disregaurd that post.. the origional one that say just take the top bolt of for the front and just the lower one for the back wheels?
Old Nov 28, 2006 | 12:22 PM
  #43
jwaggz82's Avatar
I tried that and found that it was easier just to take the whole thing off - it litterally took me an extra minute and I was able to see what was going on easier.
Old Nov 29, 2006 | 04:22 AM
  #44
vaccaro's Avatar
ok just checking.
Old Nov 29, 2006 | 12:14 PM
  #45
jwaggz82's Avatar
ok just checking.
thats fine - its better to ask before you start. Overall ...after I got done I was like "i heard people say it was easy to change the pads ....but it was even easier"
The main factor is time. It prob will be easier to change one set at a time ..front or back. Make sure you have a few hours and dont drink too many beers cause you might over torque something (hehe). Other then that ...you should be good. I bled my line just so it was easier to push the caliper piston in. I bought a self bleeding thing from the autobody store for like $4-7.
Old Nov 29, 2006 | 12:18 PM
  #46
vaccaro's Avatar
ok just checking.
how does the brake bleeding thing go again.. i forget last time i did that was in 2000
Old Nov 29, 2006 | 05:52 PM
  #47
jwaggz82's Avatar
^ on the back of the caliper there is a rubber nipple thing over a small bleeder screw. Take the self bleeding kit from the store....hook the hose up to it .... then slowly open the screw. Put a bit of pressure on the piston - the fluid should drain easily into the bleeding bottle thing. If it doesnt drain when you put pressure on the piston open up the bleeding valve a bit more. Bleeding requires very little strain. If the valve is open up enough you should see it drain into the bleeding bottle easily. Since I used the bleeding kit it was very easy to compress the piston w/ the clamp I had because I was not pushing the fluid back into the line.
Old Nov 29, 2006 | 10:32 PM
  #48
krdshrk's Avatar
Holy crap dude... You've obviously not had to bleed the entire system.
I had to use 2 feet to get my brake pedal down. Ask Matt & Gary - they helped me with it. You should feel my brakes now!
Old Nov 30, 2006 | 12:29 AM
  #49
engifineer's Avatar
^^ Should take no more force than normal hard braking. But again, not needed for simply swapping the pads though.
Old Nov 30, 2006 | 04:43 AM
  #50
krdshrk's Avatar
Yeah, well, I switched brake lines, pads, and rotors too that's why.
Old Dec 3, 2006 | 05:54 AM
  #51
vaccaro's Avatar
謝謝所有您的幫助人
Old Dec 3, 2006 | 05:56 AM
  #52
Spect2K3's Avatar
你很欢迎
Old Dec 3, 2006 | 05:59 AM
  #53
vaccaro's Avatar
haha cool.. i though i was the only one who spoke chinese in here.
  #54
vaccaro's Avatar
我仍然学会从我的女朋友
Old Dec 3, 2006 | 06:00 AM
  #55
vaccaro's Avatar
how is my chinese so far?
Old Dec 3, 2006 | 06:01 AM
  #56
Spect2K3's Avatar
我用一个词翻译和中文不说话.虽然有趣.
Okay, no more chinese lol...my translator is bugging out, i think we threadjacked this anyway...lets stick to brakes
Old Dec 3, 2006 | 06:03 AM
  #57
Spect2K3's Avatar
I'm sure it was better than mine, I was using the translator lol
  #58
vaccaro's Avatar
haah ur translator?
  #59
vaccaro's Avatar
haah babel fish?
Old Dec 3, 2006 | 06:04 AM
  #60
Spect2K3's Avatar
Yea, it works well:
http://www.google.com/language_tools?hl=en
