2004-2006.5 [NCP61]
Headlight problem
Old Feb 4, 2008 | 09:09 AM
motz's Avatar
Default Headlight problem
my left side head light is not working somehow!
it turns on but its sooo dim its not even bright enough to see the road.
my right side is totally fine and i replaced with new bulb but the left side is
still not working.
how could that be?
is it the fuse?
or something wrong with the soket?
Old Feb 4, 2008 | 09:59 AM
SquallLHeart's Avatar
is the bulb working?
could be a fuse...
Old Feb 4, 2008 | 10:24 AM
motz's Avatar
yes it is working.
the bulb works for right wont work for left.
the fuse..
but the question is if its the fuse, then it shouldnt be even lighten up?
Old Feb 4, 2008 | 05:41 PM
dexter_5000's Avatar
could be a grounding issue or too much resistance in a wire. since its still getting voltage just not enough voltage.
Old Feb 5, 2008 | 02:48 AM
oldmanatee's Avatar
Let's be clear, I tend to get lost being so old and all..... ;) Have you tried the bulb from the left light in the right socket? And do the other bulbs in that fixture still work? Are they dim as well? It sounds like you are not getting all the juice to one lamp, but the wires are not causing a short. If you do find a blown fuse, don't just replace it, find the cause.
Old Feb 5, 2008 | 02:37 PM
motz's Avatar
i recently installed fog lights
i thought it could be it.
so i uninstalled it and tired the headlgiht but still not working.
fuses are okay. i checked everything.
i switched the bulbs too.
ugh....
Old Feb 9, 2008 | 02:05 AM
cobb's Avatar
Where did the ground the fog lights? If i remember correctly the positive end plugs down below the battery and the negative ground rings goes by the ac dryer and it plugs into the lamps. I would look at the grounding area. Second check the voltage at the head light socket. Worse to worse, you got an excuse to upgrade to hid, which just uses one plug for a signal, then uses a relay kit on the battery, so you will not need the bad head light connection that causes your problem.
Old Feb 9, 2008 | 02:09 AM
motz's Avatar
actually, I bought HID kit but i didnt want to install it
because i thought my headlight might mess up my HID.
so is it okay to install?
Old Feb 9, 2008 | 12:09 PM
cobb's Avatar
Man, sorry to hear of your head light problem since I am going to install oem fog lights in a few weeks. My current ones use a relay kit and are hooked directly to my battery.
I do not know what hid system you have, but one I was going to buy uses a relay kit. They say the hid transformers can cause damage to some cars to the stock head light wiring, so they use a relay that uses the head light socket from the car as a trigger to turn on the independed relay from the battery.
Otherwise, I feel you would have the same problem with hid with the one not lighting or is very dim.
Old Feb 10, 2008 | 02:41 AM
RevolutionAutomotive's Avatar
Scionetics
I know it sounds odd, but sometimes a fuse can actually *pop* but still look like its together and still send a signal. We had an audio install do it. However, the fuse only lets a small amount of power through and will still show that its working through a fuse tester. You know the little white stick with the green light. It is blown however and needs to be replaced. Other than that, check your wiring to your headlight. Check for any cuts in your wiring and check both the inside and outside fuse boxes.
Old Feb 10, 2008 | 04:39 AM
motz's Avatar
thanks guys.....
i finally fixed it.
it was fuse.
it looked fine but i swtiched left and right fuses
then my right headlight became dim.
sorry i shouldve checked that at first place...
thanks guys!
S7ephavs
Mar 22, 2015 12:09 PM
2006whitexb
Mar 11, 2015 12:39 AM
missing_image
Feb 7, 2015 07:18 PM
scsteven
Jan 25, 2015 01:06 AM
