125 mph!!!
Not likely, I make semi regular trips up north and coming back over the grapevine I coast at 80 the last ~2-3 miles before Magic Mountain, and that's in a ~2,600lb car forget about a 10+ ton truck (fully loaded). I've also seen the runaway truck ramps, and the "trucks use low gear" signs. But could you post a link so I can read it.. and probably learn something.
As one who has done 85 often and frequently, hows the engine rpms at that speed? Dont think I would want to temp it over 5 grand. I try to limit to 75 tp keep it under 5 grand when taking i95 or i295.
DAMN IM SO ____ING PROUD LOL MY TOP IS LIKE ARUND 152-155 NICE HUH? WHEN I HAD THE STOCK ENGINE MY TOP WAS 115 NO OTHER 06 XA CAN GO MORE THAN THAT..THEY HAVE A GOVERNER NO MATTER WHA YOU DO EVEN DOUBLE CLUTCH OR ANYTHING CAN GET YOU FASTER..DO YOU WANT TO REMOVE THAT GOVERNER?WELL THATS ANOTHER FORUM LOL PV ME FOR DETAILS...IM SELLING ANOTHER COROLLA XRS ENGINE WITH ECU AND EVERYTHING YOU NEED..NICE ENGINE I HAVE MINE ON THE XA AND BELIEVE ME ITS FAST!
Originally Posted by SCION_XRS
DAMN IM SO flippin' PROUD LOL MY TOP IS LIKE ARUND 152-155 NICE HUH? WHEN I HAD THE STOCK ENGINE MY TOP WAS 115 NO OTHER 06 XA CAN GO MORE THAN THAT..THEY HAVE A GOVERNER NO MATTER WHA YOU DO EVEN DOUBLE CLUTCH OR ANYTHING CAN GET YOU FASTER..DO YOU WANT TO REMOVE THAT GOVERNER?WELL THATS ANOTHER FORUM LOL PV ME FOR DETAILS...IM SELLING ANOTHER COROLLA XRS ENGINE WITH ECU AND EVERYTHING YOU NEED..NICE ENGINE I HAVE MINE ON THE XA AND BELIEVE ME ITS FAST!
was just wondering what yalls tachometer is reading at 120. I go to Houston from Tyler TX alot and i run between 85 and 90 and mine usually is about 3500-4000. Also have 17in eneki so that might make a difference
Jan06xB
PostPosted: 10/18/07 9:40PM Post subject:
You aught to read the thread about trucks running down mountains in neutral and how fast they get going - will totally change your perception of air drag.
This is true, i drive for coke and on big hill i can put in the clutch and gain 10+ mph over governed speed
Originally Posted by hotbox05
there is no limiter on either xa or xb
Originally Posted by xSTANDxSTRONGx
^^ not to mention, that the limiter is actually at 118 not 115.
from what I've hear, your wheels will go faster than your car. I keep hearing that xBs are drag limited (stock power) to ~110, so off the road, negating any wind, I guess you'll get up no higher than ~118
... I keep hearing that xBs are drag limited (stock power) to ~110...
http://www.taisei.com/project_details.asp?ProjectID=43
A good Scion Lifer can do better than that on a public road any day!
