You guys want an upgraded Intake Manifold & Throttle bod
Old Dec 14, 2007 | 02:31 AM
  #121
KamikazeScion's Avatar
hahaha
Old Dec 17, 2007 | 02:07 PM
  #122
lazermike's Avatar
If the bore stroke ratio in the little 1.5 motor was different then it would respond better to what were talking about here. Since they have built an undersquare motor, designed for torque and mileage efficiency, all the changes (larger ID TB, short runner IM, possibly P&P cylinder head)are made for high rpm use. Since the valve train cant take more than 6500, your kinda fighting an uphill battle. That doesnt mean you cant improve in the coveted 4 to 6 K range, it becomes a trade off of sorts. How much low end do you lose. Whats the drivability going to be like. Do I have to mash it all the time just to get it moving. Power curve is more important, unless your all out racing. My thoughts on the keep it simple theory is, to radius the stock throttle body in the front and back sides, if theres enough material to make a difference. Coupled with trimming down the throttle shaft as much as is possible without losing reliability, would be the poor mans way to go. What you guys are talking about will work, but its almost like youll need/want aftermarket pistons, and cams to make it work, as well as the head to flow more. To that end, if anyones really interested, thats all I do is cylinder heads for the last 28+ years. Granted thier mostly motorcycle heads, and were taking them up in the 12.5K plus range w/ stuff that was designed for 9500, but the dynamics are the same. Ive done Honda, Mitsubishi, and domestic heads from time to time, but all I do is cylinder heads. Without getting into records and national championships, suffice it to say I know aluminum heads, kinda like the back of my hand..lol. My point being, if you use your head, and really think about sizing, etc, sometimes less is more.
Old Dec 18, 2007 | 03:29 PM
  #123
wansand's Avatar
Originally Posted by lastlookcustoms
any interest in a manifold with a dual injector setup for fi cars?
do you mean one injector holder on one runner, 4injector holder on each runner?
if yes then im interested but how thick and what's the diameter will the runner be?
i would run another four stock injector with it..
Will there be engine check light issue if we change to bigger alu-intake manifold and TB???
Old Dec 18, 2007 | 04:04 PM
  #124
wansand's Avatar
Originally Posted by ScionCREW
Sorry, but its definitley not going to be out in the next week.. I wont be getting the manifold plates finished until this week.
That Sux!!! Will hopefuly i can get mine done in time. Dose anybody now how much boost the stock manifold will hold up to.
heard from a fren, he tried 20psi on our black plastic..
our stock intake manifold that connect to TB diameter is 47mm if i remember correctly. but it's kind of small inside the intake manifold..
Old Dec 19, 2007 | 02:07 AM
  #125
172's Avatar
172
yes ard 47mm,so i wonder and BIG TB is going to be restricted at the manifold,so is it worth it?
Old Dec 19, 2007 | 04:22 PM
  #126
wansand's Avatar
but our TB is 45mm..
another way is to bore off 2mm, bore our stock TB from 45 to 47mm.
if only we change to alu-intake manifold, provided the
alu-intake manifold ID is 50mm then it will be a good combo.
mid-high end power will gain more.
Old Dec 19, 2007 | 04:48 PM
  #127
172's Avatar
172
2mm? isn't the butterfly valve restricted too? i mean if u bore 2mm all the way thru,unless u change the valve to a bigger 1?
Old Dec 19, 2007 | 08:04 PM
  #128
Black_Sheep_xB's Avatar
^^ yes
Old Dec 21, 2007 | 01:05 PM
  #129
wansand's Avatar
hav to change the valve too..
Old Dec 21, 2007 | 03:29 PM
  #130
lastlookcustoms's Avatar
Thats why you preorder the OBX throttle body that I sell.. 50mm... Coupled with the manifold I am fabricating, should be a good upgrade..
Old Dec 24, 2007 | 02:21 PM
  #131
Dispatcher138's Avatar
well hurry the hell up lol kidding but seriously....
Well according to the weapon-R website the price should be released tomorrow...
Old Dec 24, 2007 | 03:10 PM
  #132
INFINI's Avatar
I might consider this also if it's not hard to put back to stock for the smog check in like 4yrs
Old Dec 24, 2007 | 03:31 PM
  #133
pulling the intake, etc.,. takes like an hour the first time, 30 mins the rest
Old Dec 24, 2007 | 03:40 PM
  #134
INFINI's Avatar
Can I keep my CAI?
Old Dec 29, 2007 | 04:47 PM
  #135
wansand's Avatar
should be able to keep your cai
Old Jan 16, 2008 | 02:15 PM
  #136
750HPTC's Avatar
dear scion crew,
When will the intake manifolds be done for the scion tc and same for the cams. Whats done to your 767hp scion tc to make that power and i want all the specs and no lies period.
Old Jan 20, 2008 | 11:13 PM
  #137
MilfHunter's Avatar
whats the benefit?
Old Jan 20, 2008 | 11:55 PM
  #138
INFINI's Avatar
Originally Posted by MilfHunter
whats the benefit?
LOL, have you read any of these threads?? Sort of would be a good idea
Old Jan 21, 2008 | 12:01 AM
  #139
MilfHunter's Avatar
I understand the concept I just dont see how it adds more hp
Infini approach it in a constructive manner!
Old Jan 21, 2008 | 12:13 AM
  #140
INFINI's Avatar
Sorry if I might have embarrassed you with my comment and I did leave a smiley face
I believe all the info you seek is in this thread. Allot of people seem to come in late and ask similar questions as you did expecting us to sum up complete discussions and facts. If I misunderstood your post as among the kind I just described I am sorry. If I did not than well....
