tC tweeters
Old Mar 8, 2005 | 02:27 AM
ProjectD's Avatar
Default tC tweeters
I have a set of tweeters and I want to know if they are better than the stock tweeters. I got them for free so I don't know how good they are. They are Phoenix Digital.
Here are the specs:
Max Power: 300w/Pair
Max Continuous Power: 150W
Sensitivity: 92dB@ 1W/1M
Frequency Response: 2KHz-20KHz
Built in Crossover: 4.7uF/50V capacitor
Rated Impedance: 4 ohms
Should I put them in?
Old Mar 8, 2005 | 02:40 AM
tekniq's Avatar
I'd recommend upgrading your other components before tweeters... they are the weaker link in my opinion.. midranges are very easy to distort, haven't yet made the highs do it..
Can't wait to replace these suckers.
Old Mar 8, 2005 | 02:48 AM
ProjectD's Avatar
but do you know if the ones i have are better than stock? I wouldn't want to make my system sound worse by installing them, but then again if they are better, why should i let a good pair of tweeters go to waste.
Old Mar 8, 2005 | 03:15 AM
TurboMe's Avatar
can u actually hear the tweeters?
Old Mar 8, 2005 | 03:31 AM
tekniq's Avatar
Well, those tweeters are meant to be used with an amplifier. Your sound would probably be worse off if you installed them over the stockers which run with the regular wattage out of the head unit.
Old Mar 8, 2005 | 04:02 AM
ProjectD's Avatar
it says no amplifier needed, sorry for not mentioning that before.
Old Mar 8, 2005 | 08:47 AM
CRxB's Avatar
really wouldn't hurt to just try them out...if there's no real difference I'll stay with the stock ones. what kind of HU are you usuing right now?
Old Mar 8, 2005 | 06:46 PM
bmac's Avatar
If you have some time, why not drop one in and then use the balance to check how the new one sounds versus the old one?
Not sure it will be worth the time, but heck.. they are free and you already have em.
B-
Old Mar 8, 2005 | 06:48 PM
ProjectD's Avatar
thanks for the replies, I'm running the Kenwood DD7015 right now. I'll try them out...
Old Mar 9, 2005 | 02:21 PM
sciontc_mich's Avatar
to those who have removed the tC's tweeters.. is there a crossover involved? or is it just parallel wired off of the midrange in the door?
Old Mar 10, 2005 | 05:42 AM
bump..
anyone know if the tC uses crossovers for the tweeters?
Old Mar 10, 2005 | 05:45 AM
reagulator's Avatar
i highly doubt there is an X-over but there is only one way to find out......
Old Mar 10, 2005 | 06:33 AM
yeah take the door off.. too bad i'm in michigan and it's like 14 degrees, and i have no garage.. hey you're in california.. you can do it.. let me know
Old Mar 14, 2005 | 02:25 PM
SCI_TC_GUY's Avatar
no crossover in the doors for the tweeters........
Old Mar 14, 2005 | 03:04 PM
xnevergiveinx's Avatar
i bet you they will sound the same as the stock tweeters. it wierd, my stock rear speakers sounded better than my 6.5" fusion compnents, the components aren't built for any bass lower than 200 hz...so i lost out on those, but i spent a good amount of time drilling new holes, so whatever, i kept them. the tweeters sounded a little bit sweeter in the back.
the tC has one of the best stock systems i've ever heard
Old Mar 14, 2005 | 03:58 PM
SCI_TC_GUY's Avatar
you're rear speakers are attenuated from your front speakers.....you need to run new direct wiring to the components to get their full affect......there is some type of resistor in the wiring somewhere from the factory.....best solution is to run new better wire....
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
Rails
Feb 16, 2005 09:28 PM
Caedel
Oct 31, 2004 03:24 PM
SCI_FIRE
18
Jul 31, 2004 10:07 PM
urban_assault_XB
Jul 6, 2004 06:42 PM
