clunking noise in doors
Lately ive noticed this really loud clunking noise in my drivers door. hear it most when windows open. (of course).
What i have done to try to find the problem.
1. took door panel off drove everywhere to locate, with hand holding everything inside door skin. nothing found.
2. took the entire door apart, checked to see if there was anything loose. nothing. re-greased up everything that needed.
3. re-tightned every bolt.
4. repositioned window. which everyone should. just so you all know.
i thought i fixed the problem after i did my speaker install. but nope.
i was starting to think it wasnt in the door. but it is. dealer has no idea.
anyone else having this issue. or any ideas.
maybe it is somewhere else and noise is coming into the door through motion.
pls help soooo annoying.
Questions:
1. Any sound deadening done to the car?
2. Have you checked the wheel well liner to see if it might be loose?
3. Is it worse when turning, different speeds, bumps in the road?
no sound deadening. i am going to do it but want this problem fixed b4 hand.
wheel well liner is tight. but now you got me thinking maybe something behind it.
and only hear it when taking off, slowing down and hitting bumps. and im not talking big bumps. i mean lil bumps. stuff you would barely feel.
checked all that. after reading up some other posts by others. the sound actually sounds like it coming from the middle of the door. sounds sorta like a ball bearing in a pop can type sound.
ya i checked all that. next im thinking its my locking and handle assembly. or maybe lower sway bar end links. this ill know being it hopefully next week as i ordered the energysuspension kit. mine are dead. so if thats not it im sooo fu**in stumped.
i do appreciate all this too btw. anything right now if helpful. just more to check and try to fix.
thanx again for all your advice. i retook my door apart afew times these past weeks. went over everything again. foam taped up the whole wiring harness. speakers are good. checked all latching bolts and so on. window regulator is fine. so i just put it all back together tonite and hopefully on my wayto work i dont hear anything. if i do i then i dont know what it is. something i may have to live with. do the sound deadening and hopefully dont hear it as much.
thanks again everyone.
DaBlackBox
134
Apr 10, 2022 02:04 PM
bigzee19
Jul 1, 2015 04:26 AM
fur_pig
Dec 5, 2014 12:48 PM
