Help 08 Scion xB..
Old 03-17-2019, 10:29 PM
Honeyanrage617's Avatar
Default Help 08 Scion xB..
I am not sure if I am in the right area. Noob. Just bought a 08 Scion xB. Just hit 175k it was bought “as is” and been having MAF issues.
So, I recently changed PVC valve, spark plugs, oil & filter, I’ve gone through 3 MAF sensors in approx 2 weeks, changes air filter an took out my throttle body and cleaned it.
Today coming home from work she died on me 2x, check engine light came on. So went to get it read an it was MAF sensor. Since I just replaced this last Thursday I was able to get another one without buying one. This is my 3rd one.
What the heck hell can this be? Bad connectors/wires? Water in gas or condensation? ECU? I am just at a total loss right now. Toyota is so expensive so I’m trying not to go this route.
Any my ideas or tips that might help me figure it out would be greatly appreciated. I love this car but now I regretting it as I’m still making payments. I’m on a strict budget and just need a running vehicle for my babies.
I will be testing the voltage the MAF is getting tomorrow. I’m thinking more than 5v could be ECU? I just don’t understand why the MAF keeps failing. I work like a dog an have little time in between,
this is becoming a headache and I’m sure it’s an easy fix once I can figure it out. I want to give up but I keep going.
Someone please help me.
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; 03-17-2019 at 10:56 PM. Reason: Moved to Correct Forum by Administrator
Honeyanrage617 is offline
Old 03-19-2019, 02:58 PM
RichBinAZ's Avatar
Have a look at RickRacers post - you seem to be having the same issue
RichBinAZ is offline
Old 03-19-2019, 03:19 PM
Default thanks
Iam looking for it thanks
Old 03-21-2019, 11:07 PM
TubaTwo's Avatar
Our 2008 has a wiring harness issue that caused these same symptoms. It happened right after it went off warranty back in 2012. It was a pricey fix, but it kept the car going since then.
TubaTwo is offline
Old 03-22-2019, 07:29 PM
TubaTwo's Avatar
Here's the text of the service bulletin that @ScionFred shared with me on the forums back when I was having my problems. You can also find the entire conversation if you're interested. After the wiring harness fix, we had no problems with the car again until someone crashed into it just last week.
S-SB-0050-08
November 12, 2008
M.I.L. "ON" DTC P0101, P0172, P035 #, P2237 or P2238
Service Category
Engine/Hybrid System
Section
Engine Control
Market
USA
Applicability
Introduction
Some 2008 - 2009 model year xB vehicles may exhibit a M.I.L. "ON" with one of the following Diagnostic Trouble Codes (DTCs):
^P0101 - Mass Air Flow Circuit Range / Performance Issue
^P0172 - System Too Rich
^P035 # - Ignition Coil '# ' Primary / Secondary Circuit
^P2237 - Oxygen (A/F) Sensor Pumping Current Circuit / Open
^P2238 - Oxygen (A/F) Sensor Pumping Current Circuit Low
An improved engine wire harness has been developed and implemented in production to address this condition. Use the following repair procedure to diagnose and repair customer complaint vehicles.
Production Change Information
This TSB applies to vehicles produced BEFORE the Production Change Effective VINs shown.
Parts Information
Warranty Information
APPLICABLE WARRANTY
^This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date.
^Warranty application is limited to correction of a problem based upon a customer's specific complaint.
Required Tools & Equipment
Additional TIS Techstream units may be ordered by calling Approved Dealer Equipment (ADE).
Repair Procedure
1.Using TIS Techstream check for stored DTCs.
2.Verify one of the following DTCs is present.
^P0101
^P0172
^P035 #
^P2237
^P2238
NOTE If other DTCs are present along with any of the DTCs listed above, this TSB does NOT apply. Follow Repair Manual procedures to diagnose those DTCs.
3.Follow Repair Manual procedure to inspect the DTC-related component(s).
Refer to the Technical Information System (TIS) applicable model year Scion xB Repair Manual:
4.If the DTC-related component(s) is within Repair Manual specifications replace the engine wire harness.
5.After replacing the engine harness clear DTCs and verify that no DTCs reset. Then warm vehicle to operating temperature and test drive to verify repair.
TSB # S-SB-0050-08 November 12, 2008
This TSB applies to vehicles produced BEFORE the Production Change Effective VINs shown below.
AUTOMATIC TRANS VIN# JTLKE50E*91067111
MANUAL TRANS VIN# JTLKE50E*91067112
TubaTwo is offline
Old 03-22-2019, 09:10 PM
Default Amazon ng
S-SB-0050-08
November 12, 2008
Service Category
Section
Engine Control
Market
USA
Applicability
Introduction
Parts Information
APPLICABLE WARRANTY
Repair Procedure
^P0101
^P0172
^P035 #
^P2237
^P2238
thank you for this. I deff don’t have the money for this fix maybe not even until June. So far she is running okay since I replaced the MAF again for the 4th time. Just don’t know when she will act up again
Old 03-22-2019, 09:15 PM
TubaTwo's Avatar
@Honeyanrage617 , is your xB within the affected VIN range for that wiring harness issue?
TubaTwo is offline
Old 03-22-2019, 11:11 PM
I haven’t had a chance to check the vin yet I’m getting the kiddos settled in. I will though and let you know.
LBC28715
12-28-2018 10:01 PM
waybux
05-01-2014 10:30 PM
toasterboyohfour
09-05-2011 10:24 AM
gp1817
05-18-2011 06:26 PM
sbkob2447
04-08-2011 08:59 PM
Quick Reply: Help 08 Scion xB..
