Rear door panel removal to get to licence plate lights..
Old Jan 13, 2017 | 01:34 AM
Frederick's Avatar
Smile Rear door panel removal to get to licence plate lights..
Did a lot of searching and found nothing on how to remove the rear door panel on 2010 xB.
I have a lighted license plate holder that I want to hook into the plate lights.
Any help or advice on wiring would be great and much appreciated.
______________________________
Last edited by MR_LUV; Aug 29, 2018 at 07:36 PM. Reason: Moved to Correct Forum by Administrator
Old Jan 13, 2017 | 06:31 PM
Greg S's Avatar
Grab and yank. It's just held on with clips. Start in one of the lower corners and work your way up.
Old Jan 14, 2017 | 01:14 AM
Frederick's Avatar
Wow, thanks that was actually easy to remove. Now the black and red wire coming from the plate frame, can that be wired directly to the plates lights wires that are green and white and what is the green, positive or negative?
Thanks...
Old Jan 14, 2017 | 04:52 AM
Frederick's Avatar
Done and done..
Old Jul 17, 2018 | 08:27 PM
DownsizeToOrganize's Avatar
Thanks...
What was the final answer to what the green wire is?
Old Jul 17, 2018 | 10:00 PM
drizzoh's Avatar
Green is likely the positive, but tap it and find out if it works for your application. If not, tap the other 50/50 chance.
Old Jul 18, 2018 | 06:42 PM
Greg S's Avatar
Since white is always ground in Toyota cars the green is the power wire. Also, the parking light wiring is green so yeah, green is positive.
Old Jul 18, 2018 | 06:52 PM
Thanks for the followup.
Old Sep 20, 2018 | 09:32 AM
SIT's Avatar
SIT
Wow, white is ground, good to know.
iheartzombies
Scion tC 1G ICE & Interior
Aug 28, 2008 01:36 AM
cubanix
Aug 2, 2008 04:12 AM
AKScionxb
27
Dec 6, 2006 03:58 PM
aifan8703
Scion tC 1G Aero & Exterior
11
Jul 7, 2006 03:22 AM
tC_Normo
Oct 2, 2005 09:29 PM
