Epidemic Water Pump Problem!
Old Oct 11, 2009 | 03:58 PM
  #101
elwaylite's Avatar
Agreed.
Old Oct 11, 2009 | 11:28 PM
  #102
azylstra's Avatar
http://www.toyotanation.com/forum/ar.../t-171517.html
"Toyota has begun phasing in the new PINK coolant in place of the older
RED coolant. The new pink coolant is premixed with distilled water and
should not be diluted further. But I'd only use distilled water with
ANY coolant.
Do not use the traditional green silicated coolant in these cars. Asian
import pumps use rubber o-ring seals and not carbide seals in domestic
cars. Silicated coolant will wear out the rubber seals in a short
period time.
The pink coolant is meant for longer service life. But industry tests
have shown cooling systems exhibited high metal weight loss (corrosion)
using Toyota Pink. This is because toyota used only half of Dexcool's
two major components of sebacate and not the 2-ethylhexanoic acid.
Sebacate doesn't become effective with any newly installed components
(like a radiator or pump) until several thousand miles later. 2EHA is
fast acting, but it is a plasticizer that can cause problems with some
gasket materials.
So pick up some of the older red coolant (and distilled water) if you
can still find it."
Old Oct 12, 2009 | 12:24 AM
  #103
XD40tC's Avatar
Is the pink causing our leaks?
Old Oct 12, 2009 | 05:43 AM
  #104
hothotpete's Avatar
@XD40tC: nope. our water pumps are causing the leaks.
Old Oct 12, 2009 | 12:52 PM
  #105
XD40tC's Avatar
I want an electric one... someone find one that'll fit!
Old Oct 12, 2009 | 02:47 PM
  #106
jnaval's Avatar
Or we can install a... hand pump.
Old Oct 12, 2009 | 04:42 PM
  #107
TscionO's Avatar
Originally Posted by TscionO
i just bought a new water pump, off of these guys
http://toyotapartszone.com
pretty good prices and customer service
getting it installed this weekend, lets see if it works
I have heard some bad news about these pumps?? Anyone else heard? my mechanic was telling me it might have been a bad batch, so i duno. Atleast my matchbox (name of my car) is all good again
I saved like 130 bucks from buying it at a dealership yay for http://toyotapartszone.com
Old Oct 12, 2009 | 05:24 PM
  #108
HATEnFATE's Avatar
If the Coolant was the major cause of the failure of our pumps then there would be failures across the entire lineup of the Toyota(Lexus,Scion) brand, not just a model or two.
Dont' believe everything you read on the internet. You know if you find the right website.......Daewoo makes the best cars in the world hands down. LoL
Old Oct 12, 2009 | 07:06 PM
  #109
XD40tC's Avatar
Im gonna see if I can have them let me keep the old pump so I can send it to an Electric pump manufacturer for mass production
Old Oct 13, 2009 | 12:50 AM
  #110
hothotpete's Avatar
lol i was just thinking that too. you can tell who works for the dealership... ;)
Old Oct 13, 2009 | 12:51 AM
  #111
CIONIDE's Avatar
Originally Posted by CIONIDE
I've got the pink spray line on the bottom of my hood too (47k miles); I guess it's off to the dealership.
Warranty replaced today.
If it's out of warranty & you're paying for it, if you request the old parts, they have to give them to you. If it's a warranty replacement, manufacturers usually require that the defective part be returned before the dealership will be reimbursed for the warranty repair. Not sure if Toyota works like this, but Acura did.
Old Oct 13, 2009 | 02:19 AM
  #112
hothotpete's Avatar
They won't let you keep it if it was done under warranty. we get reimbursed for the broken part
Old Oct 13, 2009 | 04:20 AM
  #113
roXor_boXor's Avatar
Ditto for me at 26,500 miles.
I found it interesting after I left I noticed that the service document included this statement under the parts:
"00295-00103 - FIPG OIL PAN - WARRANTY"
They never mentioned anything about the oil pan. Does that mean they used the FIPG for the oil pan on the water pump seal or that they did the same thing to my oil pan that Pete did to his? It looks like they just used the FIPG.
Gonna call them tomorrow to confirm.
Old Oct 13, 2009 | 04:35 AM
  #114
CIONIDE's Avatar
boXor, I've got no answer for your question, but haven't seen you on the boards for a while and just wanted to say welcome back. Glad to know there were no flames involved with the water pump replacement lol.
Old Oct 13, 2009 | 01:40 PM
  #115
HATEnFATE's Avatar
"FIPG OIL PAN" is just a description of the "Form In Place Gasket" that we use. It's designed for use on oil and coolant application. It's black in color.
The description sets it apart from the FIPG that is used for transmissions which is different, "FIPG TRANS," which is an orangish-red.
Dealer.....what.......Parts Guy......huh.......;)
Been here for 9 years.
Old Oct 13, 2009 | 03:37 PM
  #116
AAG's Avatar
AAG
DeepSouth Scions
Can anyone advise how long this process takes? Is this bring it in and pick up your vehicle the next morning? I pm'd a local Toyota service advisor on a different forum I visit and I'm waiting for a response back.
Old Oct 13, 2009 | 04:03 PM
  #117
CIONIDE's Avatar
I dropped mine off at 8:30am, and rec'd a call at 4pm saying it was done, come pick it up. This also included my local Toyota dealership going to another Toyota/Scion dealership to p/u the pump because they didn't have one in stock.
As long as you make sure they have the parts in stock & schedule the repair ahead of time, they should be able to do it in one day.
Old Oct 13, 2009 | 07:37 PM
  #118
HATEnFATE's Avatar
^^^x2
Old Oct 13, 2009 | 10:22 PM
  #119
Omikron77's Avatar
Default Time
Dropped mine of at 8am and it was ready by 12:30pm....
Old Oct 13, 2009 | 11:35 PM
  #120
hothotpete's Avatar
i can get water pumps done in an hour, depending on the application. xB's have that stupid mount in the way so it takes me like 1.5 hours for those.
FIPG is used to seal stuff instead of traditional metal gaskets. the oil pan FIPG is just the black stuff instead of the trans FIPG, which is like a red. i think HATEnFATE covered that ^^
factory trained technician ftw ;)
