Epidemic Water Pump Problem!
I dropped mine off at 8:30am, and rec'd a call at 4pm saying it was done, come pick it up. This also included my local Toyota dealership going to another Toyota/Scion dealership to p/u the pump because they didn't have one in stock.
As long as you make sure they have the parts in stock & schedule the repair ahead of time, they should be able to do it in one day.
I had a slightly different time required. About 73 hours by my estimate.
"Say what!", you say?
Dropped by to get them to verify it was bad and set up an appointment on Friday at 1pm. They confirmed the leak and said they had the parts, did I just want to get it done now. Said it would take a couple hours. I said sure and had them give me a ride back to work.
After work, a co-worker gave me a ride back to the dealer. Just as we pulled in the drive, the service advisor called my cell and said, "umm we have a problem". It seems the tech had checked for the pump availability thinking it was the same one as the 2.4L Camry. Nope.
My car was already apart and pump not available until Monday.
I ended up driving a Prius home for the weekend.
Pump came in Monday about 10:30am and I picked it up about 2pm (about 73 hours later).
Hey stuff happens. They felt pretty bad and obviously the loaner was no charge. Other than the p/n oops, all went smoothly.
Took mine to dealer today. They inspected completely for any leaks and found none. Said water pump was clean and had no signs of leakage (I did not have the spray on hood though from belt), and just topped my fluid for me.
So I will keep watching and see if fluid should drop anymore.
so how many gallons for a full flush, im going in today to get a free flush :D back to hot pink :D
appointment is at noon...want to make sure that they don't just dump whats visible so that only pink is in the reservoir...
also the flush goes like this:
drain, start car-let radiator turn on-turn off car-drain, fill reservoir, start car-let radiator turn on-turn off car-drain, and fill reservoir...
i believe thats it...it might be one more time in there with the on and off and drain...but i think thats it...so maybe one gallon is enough..hmm...
mine has the stripe on the hood insulation aswell and down maybe a quart of coolant. my xb only has 20,000 miles on it, but i noticed it before that.
i'll change it when the leak gets worse or it starts making noise.
Why not just take it to the dealer and get it replaced? Just curious.
On a side note, I don't understand why so many people are deathly afraid of dealers, especially for warranty type work. If they screw something up, they have to fix it, regardless. Unless you have a very shady dealer and have no other dealers nearby, I don't understand why you wouldn't!
I've had my fair share of bad experiences (foriegn and domestic) and avoid dealers at all cost because 9 out 10 dealers suck. I'm still holding out on the pump thing until it becomes a really serious issue. I'm going on two weeks without having to top off the fluid but maybe its just a fluke...
I also have the A-pillar creak but I'm not going to take it in even though there is a TSB for it. Having the panels scratched and misaligned is almost a guarantee. I'll live with the noise (which is rarely because I always have the radio blasting lol).
If your pump is leaking...don't wait to get it replaced. Dont' forget that your cooling system is pressurized every time your car hits operating temp. All it will take is one more time to have a total failure. If you don't have to pay, get it done before it become a bigger problem. What would you rather the dealer replace, a water pump, or a whole engine? I'm thinking one offers a little more opportunity for mistakes then the other.
I am with you on the creaking issue. Mine is pretty bad, but only if radio is off do I hear it. I think of it as the car's personality... Its an econobox, not a Lexus. I spend less then 20k on it, I won't expect perfection. If it does not jeopardize my safety or is a serious problem, it's best left alone, usually. Not to mention, the people who did have the TSB done usually still have creaking, so why bother
