Broken bolt..
Old Nov 15, 2020 | 12:34 PM
aesteed77's Avatar
Default Broken bolt..
I was changing my spark plugs when a bolt broke off holding the ignition coil/plug wire down. Can't get a drill in there to extract it that way. Now my check engine light and what looks like the traction control light is on.
Any ideas?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Nov 15, 2020 at 05:25 PM. Reason: Moved to Correct Forum by Administrator
Old Nov 15, 2020 | 03:39 PM
62Fender's Avatar
What's blocking your drill, the hood? Looks like a couple of threads are standing above the valve cover. Maybe enough for mini vice grip pliers?
What's the p code for your check engine light?
Old Nov 15, 2020 | 04:20 PM
Birsan's Avatar
@aesteed77, You may try to heat that area. The coefficient for aluminum is 2.4 twice that of iron (steel). This means that an equal temperature change will produce twice as much change in the length of a aluminum as for a bolt of iron. Then slowly try to use a classic old plier tool with a nice holding shape design. What is left from that bolt should come out with no problem very fast. About the heat source. Just be sure you will use something in a way that is considered safe (this is how I do in New Jersey).
Old Nov 16, 2020 | 01:11 AM
aesteed77's Avatar
Default Success
I bought a 90° drill attachment. Used a #1 screw extractor and she came right out. Glad it wasn't a nightmare situation.
Thanks for all the suggestions. Doing front brake pads next weekend 🤞
Old Nov 17, 2020 | 12:54 AM
62Fender's Avatar
I would have never guessed you could get it with the adapter. I can't even use those things in the open. Well done!
Rizzie
Apr 10, 2013 10:12 PM
Barrykinz
Feb 11, 2013 02:34 AM
wlfpck
Jul 24, 2011 10:15 PM
Neothin
Aug 17, 2010 07:12 PM
Kong
11
Oct 23, 2004 10:04 PM
