Rear door panel removal to get to licence plate lights..
Old 01-13-2017, 01:34 AM
Frederick's Avatar
Smile Rear door panel removal to get to licence plate lights..
Did a lot of searching and found nothing on how to remove the rear door panel on 2010 xB.
I have a lighted license plate holder that I want to hook into the plate lights.
Any help or advice on wiring would be great and much appreciated.
Last edited by MR_LUV; 08-29-2018 at 07:36 PM. Reason: Moved to Correct Forum by Administrator
Frederick is offline
Old 01-13-2017, 06:31 PM
Greg S's Avatar
Grab and yank. It's just held on with clips. Start in one of the lower corners and work your way up.
Greg S is offline
Old 01-14-2017, 01:14 AM
Frederick's Avatar
Wow, thanks that was actually easy to remove. Now the black and red wire coming from the plate frame, can that be wired directly to the plates lights wires that are green and white and what is the green, positive or negative?
Thanks...
Old 01-14-2017, 04:52 AM
Frederick's Avatar
Done and done..
Old 07-17-2018, 08:27 PM
DownsizeToOrganize's Avatar
Thanks...
What was the final answer to what the green wire is?
DownsizeToOrganize is offline
Old 07-17-2018, 10:00 PM
drizzoh's Avatar
Green is likely the positive, but tap it and find out if it works for your application. If not, tap the other 50/50 chance.
drizzoh is offline
Old 07-18-2018, 06:42 PM
Greg S's Avatar
Since white is always ground in Toyota cars the green is the power wire. Also, the parking light wiring is green so yeah, green is positive.
Greg S is offline
Old 07-18-2018, 06:52 PM
Thanks for the followup.
Old 09-20-2018, 09:32 AM
SIT
SIT's Avatar
Wow, white is ground, good to know.
SIT is offline
iheartzombies
Scion tC 1G ICE & Interior
08-28-2008 01:36 AM
cubanix
08-02-2008 04:12 AM
AKScionxb
27
12-06-2006 03:58 PM
aifan8703
Scion tC 1G Aero & Exterior
11
07-07-2006 03:22 AM
tC_Normo
10-02-2005 09:29 PM
Quick Reply: Rear door panel removal to get to licence plate lights..
